588,487 active members*
5,051 visitors online*
Results 1 to 9 of 9
    Apr 2008
    4
    spindle wont turn
    I purchased (2) used Partner 6's with the Centurion 5 controlers. These were running machines that were actually making parts when I bought them. I've now got them all set-up and ready to run in my shop, but when I run a progran the spindle wont turn. Even when I try running one of the previous owners old programs the still spindle doesn't turn.
    Does anyone have any idea what's wrong?
    Sorry, i thought it was a lathe, my mistake
    Jan 2007
    333
    I've seen some spindles that won't run unless the coolant is on.
    Sep 2007
    34
    We have a milltronics and the operator came to get me because the machine wouldn't work anymore. He had the spindle overide turned all the way down to 0.
    Oct 2006
    179
    Quote Originally Posted by jkinz56 View Post
    Try commanding a S500M3 in the MDI menu. Does the spindle turn on then? Does the control think that the spindle is on? In the information box, does it say the spindle is OFF, CW, or CCW? What is displayed on the spindle inverter when you command the spindle to rotate?
    Dec 2005
    61
    Try and hit the tool change reset button if the spindle works after that then you have a limit switch shorted to ground
    May 2006
    196
    Quote Originally Posted by mholden View Post
    I am having that exact problem with my vm30. That is a short problem? My repair tech was going to chase it through some relay board in the back. Could it be any limit switch, or is there a specific one I should look for.
    Dec 2005
    61
    The limit switches go to terminal block 6 7 8 and 9
    unhook the wires and see if any are shorted to ground terminal 6 to 7 is the X axis 7 to 8 is the Y axis and 8 to 9 is the Z Most likely the X or Y wires are shorted the switches should not be the problem.
    May 2006
    196
    You have obviously turned the spindle by hand. I have had the orient stuck and had to "unstuck " it.
  1. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
  2. SX3 Spindle Motor Wont Turn ON
    By ddexd in forum Benchtop Machines
    Last Post: 02-07-2008, 01:30 PM
  3. Boss 5 series 1 BP, spindle wont start
    By signweld in forum Bridgeport / Hardinge Mills
    Last Post: 11-17-2006, 01:21 AM
  4. Ver 7.0 Eztrak 2 axis. Spindle wont turn
    By MrMudd in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:18 PM
  5. Motors wont turn
    By moto21 in forum Mach Software (ArtSoft software)
    Last Post: 09-22-2005, 04:13 PM
