587,998 active members*
1,596 visitors online*
Results 1 to 13 of 13
    Jun 2005
    142
    Need a hole that LOOKS round
    I am doing a table base from wood. Part of it is a 19" sphere with a 17" spherical viod. I want to mill three 8" holes centered on the equator. In order for them to look round they will have to be elipitical. How do I figure what the axis' for the hole?
    4826
    Art,
    Any way that you can come up with a quick sketch of what you want to do. I read it forwards and backwards and still could not imagine it
    First you get good, then you get fast. Then grouchiness sets in.
    Jun 2003
    2103
    Art is this what you are talking about?
    No greater love can a man have than this, that he give his life for a friend.
    Jun 2005
    142
    holes
    yes that is it!
    Jun 2003
    2103
    Art do you need a model of it? I didn't save it but it won't take long to make it again.
    Mike
    4826
    Where does the requirement for an ellipse come in? That's the part I don't grasp.
    Jun 2003
    2103
    Quote Originally Posted by HuFlungDung View Post
    Hu, it is one of them there elliptical illusions!
    When you look at the 8" holes from an angle there is the illusion that it is an ellipse.
    Mike
    4826
    Okay, I'll bite What is the correct viewing angle for a 19" sphere with 8" holes in it? How high should it be off the floor, and what is my ideal height and distance from the object?
    Jul 2005
    12177
    Quote Originally Posted by turmite View Post
    Mike
    That may be correct, but if you figured out the elliptical shape needed to make it look circular from one vieiwing angle it would look circular only from that viewing angle; all other views would be decidedly strange I think.
    Jun 2003
    2103
    HU, you of all people should know that! The "right" side!
    Geof I agree. This isn't my thread, I'm just trying to help Art!
    Mike
    35538
    I think the best way to make it look round is to cut a round hole.
    Apr 2007
    1955
    I am not positive about this, but I think the general approach is to take the 8 inch circular cut out and "wrap it" around the larger sphere in one direction, and flat in the other.
    If you measure 4 inches up and down along the circumference, this should give you an "actual hole" which is eliptical. Width wise, you just measure straight (not along the curvature) to make the other axis.
    It would be a good idea to double check this idea before cutting.
    4826
    I've heard that good artists (ones who can really paint realistic pictures) have a certain 'literal interpretation' of what they see. For them, looking at a hole off axis may actually look elliptical, but for the average non-artist (like myself), automatic interpretation of the object by my brain renders the ellipse into a circle because I assume it is a circle.
  1. Replies: 9
    Last Post: 02-11-2008, 05:54 PM
  2. Out of round on last cut
    By Robin Hewitt in forum Benchtop Machines
    Last Post: 08-18-2007, 01:20 AM
  3. round and round we go
    By omegaghost in forum Benchtop Machines
    Last Post: 01-10-2007, 05:25 PM
  4. job setup -round whit a hole
    By osomaker in forum Mastercam
    Last Post: 12-21-2006, 03:51 PM
  5. Round corners
    By slawsonb in forum SheetCam
    Last Post: 01-26-2006, 11:22 PM
