So I posted this thread a while ago: http://cnczone.com/forums/showthread.php?t=29579
I held off on the Grizzly. Since then I was given this Bridgeport CNC with some extras in a box:
I was told it worked last time it was used, but would often blow a fuse. I'm relatively new to CNC and I was hoping someone could point me in the right direction to get this running again. You can see some rust on it. It's a little worse now as I haven't had a chance to look at it since summer.
First obstacle for me is the lack of 3PH here. Are there any converters I should be looking at?
We had to angle the head in order to clear the garage door.You can see the new wood around the garage door. I put a hole in the wall and installed the door a few days before just to get the machine in.
Thanks you.
