Try tihs one at http://www.brandsoftheworld.com/sear...8297/4550.html
If it's not what you wanted try a search, there were a couple of other logos, but I think this is what you wanted.
Landdesign
Erik
Did you get a infraction? Your post wasn't up very long. Been There, still trying to do that.
What is possible? What you will!
Here's a carnival flag. For your holiday CNC pleasure.
can you guys use eps files? i do alot of jewelry work and I save my vector art as eps.
here is a cross I recently did as a memorial piece. may need some editing depending on what your doing. But I hope someone can use this. The picture I got to make this cross was a door knocker .
I have followed this guys blog if you go thru it you can find alot of downloads for eps and dxf files.
www.sharifaab.blogspot.com
fretsman,
Yes, you are correct, my error. Inkscape gives the option to save as EPS although when attempting to do so gives a message that the extension has not been added to the file.
Corel Draw will in fact open & save files with the Encapsulated PostScript extension. These can then be exported as DXF for CNC use.
Ah, thanks for the clarification!![]()
Dave->..
Ghostview converts .EPS files fairly cleanly, without as many "lines over lines" as when inkscape converts .SVG files. It DOES make a lot of little lines out of the arcs unless anyone can tell me a way around that.
Good morning.
how to post a dxf file in the forum?
thank you in advance.
dominique
Good morning Dominique, In order to post a DXF you need to use the "Go Advaced" option under the "Quick Reply" box. You can type your reply then go down to the "Manage Attachments" button. You can add your files (DXF, EPS, JPG etc.) from there.
Dan
Good morning.
I find models like the one I sent you
Good morning.
I find models like the one I sent you.
Test 3
2 palm trees and a cheerleader pom pom vecter
thank you,
but I do not have the software to the pronfondeur Z.
In order to have a 3D rendering
