587,383 active members*
3,605 visitors online*
Thread: Mach 3
Page 1 of 2 12
Results 1 to 20 of 24
    Apr 2008
    36
    Mach 3
    My table runs fine with Mach2, installed Mach3 but nothing happens, updated my PC to a 1Ghz, 512mg Ram. Installed Mach3 on new Pc and nothing happens, reverted to Mach2 and runs fine. Mach3 does not run on both PC's.what could be the problem?
    35538
    Your settings. Make sure that all the port address is correct, and all the pins are assigned to port1, and not port 0.
    May 2007
    250
    Lightbulb Mach
    Dear AngelT,
    I found this problem same as you. I install Mach2,everything is OK. If I install
    Mach3,I set all functions on port and pin, Motor tuning correctly. Some PC is OK/Some is not OK. Here's the summary of installation.( CPU should be more than 1.3 Ghz).
    1) Run Mach as your version.
    2) Reboot PC
    3) Place license to location of mach, Normally: C:\Mach2 or C:\Mach3
    4) Open program Mach-->check the folder of help --> about--> Have to show the name of buyer,( Not show Demo version)
    5) Set configuration--> set up port and pin and motor tuning.
    5) Check at control panel--->Performance and maintenance--->System-->hardware--->Device manager.
    Pls have a look on the driver of Mach.If it shows unknown driver,it can not run. If it shows mach2 or mach3 driver,everthing is smooth and ready to run.
    Mongkol
    Apr 2008
    36
    My CNC Router and Mach3 dont like each other...My new Pc is a dual core with 3.40ghz, 1 gb ram...have followed the instructions to configure it right. My DRO's change number but the motors don't...Do not have an estop but I disabled with a low signal...changed all ports number to 1...Don't want to go back to Mah2...Desesperado.....!!!!!
    P.D...Installed Mach2 back and everything works...!!!!
    Apr 2008
    36
    Mach3
    Love this forum, somewhere there is one with the same problem that I have.Mach3 does not run with my table but it is fine with Mach2. My table is a Solsylva 27x39 dual screwlead, HobbyCNC board with 205 motors. No home or limit switches and NO estop. this one I will intall someday for security reasons. I have disabled the estop and checked the low signal. Hit apply and OK and when going back to Imput signal table, the "estop" is enabled....!!!!somehow I think that my problem has to do with it. Anyone out there with my same setup will appreciate if you could send me a copy of their setup. As always, thanks for any imput.
    35538
    Is there an error message flashing? If so what does it say?
    I think you need the Estop enabled, and set to Active Low, even if you don't have one.
    Apr 2008
    36
    No message, estop enabled and active low signal...
    35538
    If you try to jog, do the DRO's work?
    Apr 2008
    36
    Mach3
    The DRO's change using the left,right,up and down arrows on my keyboard...
    35538
    If the DRO's are working, than Mach is working. You need to measure the voltage on your direction pins while jogging. Should be 5V in one direction, 0V in the other. If the voltage is not changing, you're port address is wrong or some ports and pin settings are wrong.
    Jun 2007
    3734
    Question Is it a charge pump problem?
    I have seen this with DRO's changing and no movement jogging.
    Traced it charge pump disabling the drives.
    Initially disabling charge pump function (in your hardware) to get it going is easiest. If the charge pump signal is not being directed to the appropriate pin the drivers won't move.
    This requires setting a jumper at BOB level, or something. See your BOB documentation.
    I am not familiar with your system, but sounds like a charge pump issue.
    The charge pump is meant to keep the external hardware alive, so that if the PC dies or stops, the charge pump (not being pumped now) disables the drives.
    Apr 2008
    36
    Mach3
    checked the charge pump in Config>state...same problem BTW...what is a BOB? thanks for the imput
    Jun 2007
    3734
    Question What is BOB.
    Break Out Board is the interface between the PC parallel port cable and your drivers. As I noted some BOB's are configured to require a charge pump signal but which pin yours may require is what you may need to find out, if it is your problem.
    Jun 2004
    6618
    I have had this happen in Mach 3 and on the diagnostics page, the frequency would say "Simulate". The only thing I did was to install the Special Driver.bat from the Mach 3 folder. This didn't fix it, but then I installed the original driver.bat from the same folder and it all worked okay then. Try a driver test in the mach 3 folder as well.
    Lee
    Apr 2008
    36
    Mach3
    Will like to know if anyone has a table with HobbyCNC board and 205 oz steppers, no limit switches and Estop and send me a copy of their XLM file that is in Mach3. I compare it to my XLM.
    Apr 2008
    36
    Finally had Mach3 configured out right, the problems was that the Ports Pins and Port dir were backward. Had it working for about two hours, went to lunch and when came back, Mach3 was not working, this time DRO's are not moving. Going back to faithfull Mach2...
    Jun 2007
    3734
    Exclamation 2 steps forward.
    1 BACKWARDS. It was working. Did something stop the charge pump for safety, like a power glitch, and you weren't there, and you've given up !!
    Shame shame !! (LOL chicken):bs:
    Apr 2006
    3498
    What Mach3 version you are using?...Is that lockdown?...please shares experience with Mach3 Ver 3.xxx...What is the difference between Mach3 Ver 1.84 and Mach3 ver 3.xx?
    Jun 2007
    3734
    Smile Mach 3.04
    Win2000 Mach3 3.15 ooooops!
    Correction: :withstupi
    Got the title right. Dunno where I the 15 from.
    I meant 3.04
    Apr 2006
    3498
    Mach3 Ver3.15 not released ...The last version is 3.04 i think...
Page 1 of 2 12
  1. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  2. K2 With Mach III?
    By GuitarEng in forum Commercial CNC Wood Routers
    Last Post: 11-11-2006, 02:18 AM
  3. Mach 3 no spindle - but OK in Mach 2
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2006, 01:38 PM
  4. Moving to mach 3 need exact mach 2 screen
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2005, 10:00 PM
  5. will mach 2 or mach 3 work for 4 axis cnc?
    By Runner4404spd in forum Mach Mill
    Last Post: 10-05-2005, 05:44 PM
