Originally Posted by
ger21
Again, not entirely true. At very low speeds, a stepper motors torque is proportional to current, not voltage. If your turning at 10rpm, you'll have the same torque using a 24V supply as you will with a 50V supply. But as a steppers rpm increases, the torque starts to decrease. The point at which the usable torque falls off, however, is proportional to voltage. So if you can run your machine at 500rpm with 24V, you should be able to run it at 1000rpm at 50V.
There's really more to it than just finding the motor with the lowest inductance, unless you've designed your machine to utilize the maximum rpm those steppers are capable of.
