588,015 active members*
7,731 visitors online*
Results 1 to 17 of 17
    Jul 2007
    887
    Heatsinking the HP-UHU
    As those of you who have assembled and disassembled the HP-UHU a few times probably know, it can be a bit tricky to do since there aren't any access-holes in the board to reach the screws for the MOSFETs.
    At first I thought it wasn't that bad but after taking it apart a few times during the initial debugging I got tired of it a decided a better way was needed. So I came up with the following:
    Here's two "clamps" that fit across the MOSFET's on the bottom side of the HP-UHU board.
    They have three M3 threaded inserts each that is used to clamp the MOSFETs to the aluminum backplate:
    Here's a closeup:
    And here's the back-side of the alu-plate, all holes countersunk...
    Then comes the big old heatsink. I've attached a piece of aluminum sheet-metal that serves as a mounting bracket:
    And here's the finished 'package':
    Hopefully this will help other HP-UHU builders out there, thanks for looking.
    /Henrik.
    1050
    HI Henrik, do you have the dimensions of the clamps? or a drawing you could post ,
    any ways thanks for the brilliant ideas!
    RGDS
    Irfan
    Jul 2007
    887
    Hi Irfan,
    Yes, I have drawings for the backplate and the clamps - just need to clean them up a bit....then I'll upload them here.
    Thanks!
    /Henrik.
    1050
    how did you fix the 7805 henrik?
    Jul 2007
    887
    Hello,
    The 7805 is mounted with M3 screw and nut from the back of the plate, it's quite easy to reach in with a pair of pliers to access the nut so I didn't bother making a clamp for it.
    Attached are two drawings, one for the clamps and one for the backplate. Please note that the hole for mounting the 7805 regulator is missing in the drawing...
    /Henrik.
    Attached Files Attached Files
    Nov 2006
    70
    Great job Henrik, congratulation!
    And thanks for the super documentation and photos ...
    Jozsi
    1050
    Hi Henrik, are you using any thermal conductive paste between the flat Alu plate and the bigger heat sink?
    RGDS
    Irfan
    Jul 2007
    887
    Irfan,
    Yes and no.... There's no thermal paste applied at the moment but I'm going to add that once I'm certain I'm not going to take it apart again.
    Thanks!
    Jun 2008
    130
    Quote Originally Posted by H.O View Post
    Irfan,
    Thanks!
    You could use Arctic Silver 5 which is popular for computer heatsinks; it works very well, and is not sticky. The tube looks pretty small but it goes a long way, you only need a very thin layer. Jim
    No time to do it right, plenty of time to do it twice.
    1050
    Quote Originally Posted by youngjim View Post
    i use something call pate340
    its good, but I would like a pad, which I would cut to what ever size i want and paste it on the Alu heatsink, just a matter of comfort!
    RGDS
    Irfan
    Aug 2006
    2758
    Great idea!!!, Simple and beautiful.
    Congratulations!!
    Kreutz
    Dec 2005
    231
    Hello,
    /Henrik.
    Hi Henrik,
    What type of material did you use for the clamps?
    John
    Dec 2005
    231
    Hi Irfan,
    Thanks!
    /Henrik.
    Hi Henrik,
    Do you have a source for the heatsink material?
    John
    1050
    I am planning to use Hylam, Henrik even I had that Q, seems like some sort of epoxy cloth of fiber?
    Jul 2007
    887
    Hi guys,
    I got the heatsink from a scrapped MIG-inverter, I managed to squeeze out three HP-UHU sized heatsinks from a single large one - it was the mother of all heatsinks.... A qualified guess on my part though is that such a large heatsink isn't really needed - I just used what I had.
    The material for the clamps is indeed some kind of epoxy/fiberglass, just like FR4 circuitboard material but a lot thicker. I guess bakelite/hylam, delrin, plexiglass or some other kind of fairly hard plastic should do it. You COULD make them in aluminum but then they need to be a bit thinner or the clearance may be on the low side....
    And the alu-plate backplate, well...that's just a 4mm alu-plate.
    HTH
    /Henrik.
    1050
    my heatsink clamps
    since i don't have a milling machine at hand, decided to use super glue and 3 mm thk hylam to use for the clamps with nuts embedded in between.
    started of with my hacksaw and bench drill!
    looks very crude but should work. will post you the clamp affixed pictures soon.
    pictures are from a crappy Motorola E6 rockr ... kindly excuse!
    Aug 2009
    7
    Extra job
    Extra job Henrik
    /Robert - phoenix_1
