588,548 active members*
5,678 visitors online*
Results 1 to 6 of 6
    Apr 2004
    10
    Printing on hard surface tile?
    I want to print on a hard piece of plastic, approximately 4" x 4" square. The material is also approximately 1/4" thick. Does anyone think I could modify an old inkjet printer to feed this through? The material obviously will not flex through the rollers as is but maybe if I remove enough of the case to just slide it in through the rear?....
    I have both an old Canon 1000 & a Canon 3000 to disassemble...
    Has anyone experimented on something like this? I though I remember reading about someone who did this to print directly onto CD's but can not find it anymore.
    or does anyone know where I should be looking?
    jeff
    Mar 2004
    222
    try THIS.
    I think you'd need a special ink, quick drying ones as media has
    special coating for the ink to adhere.
    :cheers:
    mhel
    "This is intentionally left blank."
    Apr 2004
    10
    Thanks - thats a good start. Now I'm off to destroy my old printer!! ;-)
    I was also thinking I might have an ink "drying" problem - or I might have to adjust my material. This is still in the creation phase so I still have some flexability.
    If anyone comes up with any great ideas, please let me know.
    Jeff
    Aug 2004
    170
    Hi there. EPSON created a new type of ink. Your Cannon printers are not prepared to use it, because they are not PIEZO. Cannon uses the BUBLE JET technologies, like HP. That´s because the Epson ones got blocked-up...
    Better search for another print head...
    See ya! Ito-Brazil.
    Jun 2004
    67
    There's a new FlatJET from Roland DG that can print on anything up to 150mm thick (some models). It has a vacuum bed and they released new inks. I have seen the results on tile, MDF-board, fluted plastic sign sheet, plastic-faced cork mats etc.
    Worth a look to get ideas, cuz you can't afford to buy one!
    Regards, Terrence
    Sep 2003
    1113
    Suppose you considered heat transfer already? Print the image - then heat tx it to the object. Just need to watch the plastic melting... Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. A2100 Hard Disks
    By tricky in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2018, 08:33 AM
  2. A2100 Cincinati Hard Disks
    By tricky in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2005, 02:03 PM
  3. 3D wireframe surface
    By JW Peters in forum Autodesk
    Last Post: 05-10-2005, 01:23 AM
  4. Using the difference function ?
    By Ken_Shea in forum OneCNC
    Last Post: 09-21-2003, 12:11 PM
  5. Surface Hatching option ?
    Last Post: 06-13-2003, 06:28 PM
