587,128 active members*
3,133 visitors online*
Results 1 to 3 of 3
    Mar 2004
    576
    Can I remove this from my mill head?
    I know this is used for the quill extension indicator, but is it supporting anything else? Or can I just remove it? I never use it (as the quill is CNC'ed on my mill), and it gets in the way of clamps etc regularly.
    Thanks,
    -Neil.
    Feb 2004
    361
    looks the same as the one here in the garage...
    just a vertical depth indicator....and sometimes used as a limit stop...
    should be ok to remove, don't see why not...???
    ..enjoy..
    Oct 2006
    59
    This looks the same as on my HF Mill/drill and I removed it and replaced it with a linkage for a cheapie DRO. So, I guess, it really doesn't need to be there! :devious:
  1. Weird Seemingly useless part on CNC Taig Mill, Can I remove this? (pic)
    By scubasteve_911 in forum Taig Mills / Lathes
    Last Post: 10-08-2014, 04:30 AM
  2. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
  3. Help - remove head on 45 Square Col Mill
    By kramerda in forum Benchtop Machines
    Last Post: 12-22-2007, 04:49 PM
  4. Mill head
    By MrRage in forum Benchtop Machines
    Last Post: 11-06-2005, 09:20 PM
