588,234 active members*
4,601 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > ArtCam Pro and Mach3
Results 1 to 6 of 6
    Apr 2008
    36
    Saved my art as an.nc file in inches and when it is opened in Mach3 it shows dimensions in metric...my CNC router goes crazy, it is all over the table....!!! Hope the British and American someday decide on one of the systems...!!!
    Apr 2008
    36
    metric vs. inches
    Related to my previous post: Could you run a vector art in metric on a Router CNC that is set in inches?
    Apr 2005
    3634
    Can you post the an.nc file?
    Or at least a few lines of code, would help.
    Free DXF - vectorink.com
    Apr 2008
    36
    For some reason I can not upload the file, I get and "invalid file format" error...
    Apr 2005
    3634
    If you .zip the file first, it should work, when you try to upload here.
    Apr 2008
    36
    found problem
    Found the problem...when I saved the file in toolpath, in the machine output file there is an option for metric or inches with Axyz_Arc_(*nc), now it works fine. But I have other problem, I know it is the learning curve of ArtCam Pro. How do you combine letters on an existing Art work? My art is a template with letters on it, when the file is sent to the router, it only carves the template and not the letters. Bear with me, new to ArtCam Pro. Thanks for any help...
  1. ArtCam Pro
    By cncadmin in forum ArtCam Pro
    Last Post: 07-27-2015, 10:12 AM
  2. MACH3 Post Processor for ArtCAM
    By TomL21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 12-31-2011, 02:56 AM
  3. How much is Artcam Pro?
    By alexccmeister in forum ArtCam Pro
    Last Post: 12-25-2011, 05:16 PM
  4. ArtCAM & Mach3 for Plasma and Oxy
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 05-31-2006, 07:01 PM
