603,314 active members*
3,170 visitors online*
Results 1 to 20 of 113
    Mar 2007
    534
    The fast traverse is a completely separate interrupt handler, precise placement only happens at speeds where the motors can handle an instantaneous reversal.
    There is more work to do. When it encounters back lash it will tend to trail by the tolerance and I will need extra remedial steps. OTOH I'm not going to try to fix anything until it has had a chance to tell me what needs fixing.
    I'm writing the code and everything runs in SRAM. I can recompile and upload all new in a matter of seconds. I am in control
    Jun 2007
    20
    Hi Robin. What a brilliant idea. When you get it right you will have solved one of the major issues with using steppers. i would be interested in the outcome.I had another thought that if i had the knowhow would be worth pursuing. What if you had a PIC counting pulses sent my Mach 3 and then the PIC moved the stepper motor using the encoder to go to the correct position? Its probably complicated, and you would get some lag,but i would gladly put up with lag for accuracy.
    Aug 2008
    573
    Hmmm , That wouldn't be too difficult.
    I use a PIC (16F84 and an L6219) to drive the Z motor on my engraver, it'll happily keep up with the step inputs from the controller using interrupts. It even has has a couple of unused timer/counters that could be used to track an encoder. Might be worth a look
    [I still wonder, if you're going to add all this complexity you might be better of using proper servo-motors]
    Jun 2007
    20
    Smile
    Quote Originally Posted by BillTodd View Post
    Yeah. you could be right, but steppers and encoders on ebay are a lot cheaper than servos, and if a cheap PIC could be made to act as a Pseudo closed loop it would be just as good for a lot less money for the DIYers
    Jul 2011
    tried the circuit with verniers too
    but no data
    Aug 2008
    573
    Quote Originally Posted by aadityadengle View Post
    but no data
    :bs:
    :bs: like that's going to get you an answer !
    Bill
    Feb 2012
    26
    Hi Bill,
    first off, you might want to think about adding a donate button to you signature!4 years later and there are people still interested in your work.
    You got me to join another forum just to ask you a question. Pretty simple one it should be:
    Do I need visual studio to get your program to install? I keep getting:
    unable to register the dll ocx regsvr32 failed with exit code 0x4
    on both my computers.
    looking forward to your response.
    Regards
    George
    Aug 2008
    573
    Hi George,
    The program is written in VB5, so you should not need VS at all.
    It was designed for Windows 95. I have not tried it on Vista or Win7, so that may be the problem (can you install on a VM or as XP?).
    the install script ireads:
    Source: "d:\My Documents\VB5 projects\Logger\Vernier.exe"; DestDir: "{app}"; Flags: ignoreversion
    Source: "e:\VB\System Files\MSVBVM50.dll"; DestDir: "{sys}"; Flags: onlyifdoesntexist uninsneveruninstall
    Source: "e:\VB\System Files\OleAut32.dll"; DestDir: "{sys}"; Flags: onlyifdoesntexist sharedfile regserver
    Source: "e:\VB\System Files\OlePro32.dll"; DestDir: "{sys}"; Flags: sharedfile regserver
    Source: "e:\VB\System Files\AsycFilt.dll"; DestDir: "{sys}"; Flags: sharedfile
    ;Source: "e:\VB\System Files\Ctl3d32.dll"; DestDir: "{sys}"; Flags: sharedfile
    Source: "e:\VB\System Files\StdOle2.tlb"; DestDir: "{sys}"; Flags: sharedfile
    Source: "e:\VB\System Files\MSCOMM32.OCX"; DestDir: "{sys}"; Flags: sharedfile regserver
    Source: "e:\VB\System Files\SCRRUN.DLL"; DestDir: "{sys}"; Flags: sharedfile
    Source: "e:\VB\System Files\comcat v471\Comcat.dll"; DestDir: "{sys}"; Flags: sharedfile regserver
    so there are only 4 files that require regserver.
    4 years? I started this in 2005! that's the problem!
    There are new scales out now that do not work with the PIC code (so be warned) At some point (way in the future), when I get one of the newer 21 bit devices I'll add it to the PIC.
    Meanwhile, I get people like aadityadengle waving bs flags at me, because they cant get it working!
    Is does work with the right scales:
    [ame="http://www.youtube.com/watch?v=7R-qcTCTcxk"]PIC based DRO - YouTube[/ame]
    Bill
    Jul 2011
    Question
    IT DID NOT WORKED FOR ME. BUT STILL WORKING ON IT.
    Jan 2014
    3
    DRO Design discrepancies.
    Reposted to correct forum - apologies.
    I was looking with great interest at Bill Todd's DRO designs, and I really want to build this one - I am quite at home with electronic assembly and PCB manufacture - but although an impressive amount of work has obviously gone into the design, the information downloaded appears to be fragmented and inconsistent, therefore I am having problems verifying schematic to PCB layout.
    Having downloaded the Zip package for Version 1.2.05, I found the PCB layout PDF file, but there was no schematic. I downloaded the schematic separately from the forum, but one does not verify with the other. The PCB layout has numbered components and nets given, the schematic has no numbering - just question marks. I have tried tracing by eye, but there are several discrepancies. eg pin 7 of the DB9 goes nowhere on the schematic, but is connected on the PCB; there are 2 diode cathodes to 3.5V on the PCB, but only 1 on the schematic; there are 2 resistors to DB9 pin 4 on the PCB but only 1 shown on the schematic. I gave up at this point as clearly the schematic that I have is not the one that the PCB was netlisted and routed from.
    Is there a schematic and PCB layout that are a matching set somewhere, or alternatively a definitive schematic somewhere that I can confidently use to netlist and route my own PCB from?
    I really don't want to spoil a good project or waste time and money by going off half cock, so I trust some kind soul will be able to point me in the right direction.
    Thanks.
    Oct 2010
    93
    Why don't you send a PM (private message) to Bill?
    I always believe in getting information directly form the "horses mouth".... He's friendly, helpful and doesn't bite
    Joe in Aus
    Aug 2008
    573
    Re: PIC based DRO
    Hi All
    Anyone wishing to build this project should bare in mind that I designed this some years ago for use with the 1.5V (positive frame) callipers that were around at the time. Modern callipers and scales have moved to a 3v (positive or floating frame) that require a different ground and power arrangement.
    I've pretty much given up developing the PC application as there is a better Andriod tablet based app being developed by Yuriy
    (Yuriy's Toys: Android DRO Project)
    I will at some stage update the PIC code to work with Yuriy's DRO but I have little time these days (personal reasons) so it could be a while before i get a 'round tuit'
    Regards
    Bill Todd
    Bill
  1. Is water based
    By cncadmin in forum Safety Zone
    Last Post: 10-19-2022, 05:10 PM
  2. Need help with CNC UK based
    By ciscoe in forum European Club House
    Last Post: 07-21-2008, 12:03 PM
  3. Pic based Oscilloscope
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:48 PM
  4. PC Based Controls
    By zimbricd in forum News Announcements
    Last Post: 12-12-2007, 09:38 PM
  5. dos based cnc software
    By flyingmike in forum Computers / Desktops / Networking
    Last Post: 11-25-2005, 08:29 PM
