588,204 active members*
4,078 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open Source Boards Available, Stepper Drivers and Break Out Boards
Page 18 of 39 8161718192028
Results 341 to 360 of 763
  1. #341
    Jun 2004
    55
    Phil, the eagle files for the new L297/8 are missing.
    Can you please publish it so I will check it against mine ?
    Thanks.
    Pigi
  2. #342
    Aug 2004
    170
    Hi there:
    I am afraid to conect an NO-optoisolated PCB on my paralel port.
    What kind of tests can i make or have you guys other type of Break out board that are more safe? I saw on Phil´s site a Opto-isolated one, but it don´t have the lay-out... Can you help guys?
    Thanks a lot!
  3. #343
    Jun 2003
    3312
    Pigifly,
    Zip file attached here
    Attached Files Attached Files
  4. #344
    Jun 2003
    3312
    Ito,
    The important part of using a non isolated system is appropriate power common (gnd).
    You want no or miniscule current flow from the PC to the BOB. Checks really depend on what your configuration is.
    Phil
  5. #345
    Aug 2004
    170
    What do you think if i put some Sn 74LS06 as a "bridge" ?
  6. #346
    Jun 2004
    55
    Phil
    the BreakOutBoard is ready.
    Would we start a new thread "troubleshooting the Simple BOB and L297-8 driver " for every one that would realize this board ?
    In this way we can communicate between us and leave our experience for the others ?
    Pigi
    P.S. I will start it now.
  7. #347
    Jun 2003
    3312
    Ito-Brazil,
    What is your board configuration?
    Phil
  8. #348
    Aug 2004
    170
    I use 3x Discrete stepper driver. They´re not ready yet, because i can´t find the IRLZ44 MOSFETs heare. I tryed the BUK556-60 or 555, but we on´t have it heare in jungle, hahaha!
    My motors have only 3.1A and 12V Max. May I use another FET?
    Well, i am trying don´t use the breakout, just because money. What about the Sn74LS06 use to "breakout" my Drivers?
  9. #349
    Jun 2003
    3312
  10. #350
    Aug 2004
    170
    Right! This one! With the IRLZ44
  11. #351
    Jun 2003
    3312
    Ito, in effect you do have the equavalent of a 74ls06 in the 74HC14, Just make sure you wire the PC ground lines. Did you download the document for the board that has the diagram for hardwiring the driver boards?
    Phil
  12. #352
    Aug 2004
    170
    I gess we are not talking the same language, hehehehe! what I NEED is the MOSFET equivalent: IRLZ44 . this part simply don´t exist heare. I´m tryingo in other states, but not many successfully.
    But thanks anyway, if you know about an IRLZ44 equivalent, or some FET to drive my 3.1A / 12V motors, please let me know ok?
  13. #353
    Mar 2004
    18
    Hi, Can someone write up a parts list for the 4axis breakout board??
    Greatly appreciated.
  14. #354
    Jun 2003
    3312
    timewarp,
    Have you started yet? I have a slighlty newer version that is not posted on the web, that adds a led to display the estop state.
    Phil
  15. #355
    Jun 2003
    3312
    ITO,
    If you glean back through this thread I belive Tachus42 gave another number.
    Phil
  16. #356
    Jun 2003
    3312
    timewarp:
  17. #357
    Aug 2004
    170
    I just bought the parts. The pcb kay-out are not "engraved". I will do it manually, because i don´t know how to transfer the lay-out to the board, so i will use my future CNC tool head to engrave manually the pcb´s. Where can I take the new discrete driver?
  18. #358
    Mar 2004
    18
    Phil, no I haven't started yet, Just getting some things together. I am very new to this, so i thought I'd start with the breakout board, still kind of fuzzy on picking out driver boards. Thought it would make a good general pupose Mach2 board. Any way to add joystick control, torch height? Thanks so much.
  19. #359
    Jun 2003
    3312
    Timewarp
    Good, I just uploaded new copper, layout and schematic files.
    Phil
  20. #360
    Apr 2004
    210
    If all else fail's he could use the sta406a
    http://www.alldatasheet.co.kr/datash...N/STA406A.html
    its a 6amp 60v npn quad package darlington driver. Or any of the darlington STA series which fit the needs maybe? I could be way off sarry if I am, I have not looked at the schematic for the break out board yet.
    When I get home to night I'm goign to be putting the finishing touches on my step/dir to phase controller board consisting of 2 16f84's running at 4mhz. board works already I just have to finish the drive lines going to a darlington driver setup I have consisting of 3 mp4102's and one sta406a's. its a nice quad stepper motor driver setup.
  1. Best break out boards?
    By Nigel Tufnel in forum Stepper Motors / Drives
    Last Post: 12-27-2013, 07:12 PM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
