587,773 active members*
3,231 visitors online*
Results 1 to 7 of 7
    Feb 2006
    213
    advice on longer wires
    I need to rewire my machine .Initially I was considering a mobile workstation but realized all I needed in the proximity or the work was the monitor and a mouse.
    So I am going to make an enclosure for the computer and hobby box of tricks . this unit will go under the machine ,out of the way .the machine is roughly 4'by8'. This will involve one wire run in the region of 16'.
    The original Hobby kit wires are not nearly long enough. So I am asking those of you that are electrical savvy what kind of gauge should the wires be, what is this type of wireing called and who is a good supplier any help appreciated regards mike hide
    Sep 2006
    290
    Hello Mike
    I used cable real similar to this http://www.grainger.com/Grainger/items/1YPT6
    I got mine at a local electronc supply ( ask for antenna rotor cable )
    My x axis motor control cable is at least 16ft maybe 18 I was a bit concerned it might be to long, but so far no problems.
    Good luck Kent
    Jul 2008
    28
    I got mine at Fry's and the price was great. Just make sure you get the shielded cable and ground the shield to the common wire.
    Feb 2006
    213
    Quote Originally Posted by calgrdnr View Post
    Hello Mike
    Good luck Kent
    I tried the local Grainger but they will only sell it by the spool,$360 .thanks for the help .I did get a local Quote from Greybar electric 50' for $75..if allelse fails I will buy from them .
    Feb 2006
    213
    [QUOTE=ZigMan;498268]I got mine at Fry's and the price was great. Just make sure you get the shielded cable and ground the shield to the common wire.[/QUOT
    awill trey them tomorrow ..thanks .mike hide
    Oct 2007
    33
    Is the shielding critical ?
    Just curious because I'm getting ready to wire up my jgro.
    -J
    Sep 2006
    290
    I believe it is preferred, Mine is not shielded.
    I have not had any issues yet.
    I could not find shielded, they were out and I was in a hurry J
  1. adding a longer bed
    By balsaman in forum Mini Lathe
    Last Post: 07-03-2021, 11:36 AM
  2. drill rod longer than 36"? where?
    By CNC Darren in forum DIY CNC Router Table Machines
    Last Post: 09-26-2004, 02:17 AM
  3. New longer Y
    By cncadmin in forum Benchtop Machines
    Last Post: 08-12-2004, 12:40 PM
  4. Longer Lathe Bed
    By boyd32450 in forum Benchtop Machines
    Last Post: 02-19-2004, 08:17 PM
