Originally Posted by
LeeWay
Okay, Peter.
I received the new stuff. Just added the extra generator chip to this board. Swapped out what needed swapping and regulated it down to 2.8 volts.
Viola!
The speed works perfectly with no loping. The speeds are dead on @ 3000 RPM and 6600 RPM. Within 5 or 6 revs.
At 1000 speed setting, it is like 960. 2000 is like 1980.
4000 is around 4060.
6600 is 6605.
Perfect enough for my mill for sure. I could likely fiddle with the control board to get it even closer, but this is fine. Nice and smooth operation throughout the speeds. Very nice. Thanks a bunch, Peter.
Hi Lee,
I'm really glad it solved your problem. It is almost impossible to get an open loop speed control to be spot on all the time as there are all sorts of mechanical issues such as mechanical resistance. etc. The best thing to do is set it up to be spot on at the speeds that are important.
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com/store
