Originally Posted by
brccrb
--The CNC Brain is available as a 3"x3" board with a single 100pin Hirose connector. This is the OEM version. The 5V power is supplied across the Hirose connector. The USB plugs into the board. This should fit your robotic project nicely
The main beef I had with the system suppliers that I purchased from was their efforts to miniaturize their controllers by making their I/O connectors smaller and smaller.
I realize it is probabally cost effective for them, but my point was that machine tools don't really get any smaller, why miniaturize the connector?!
From the likes of Mitsubishi/Fanuc using micro/mini D sockets, and Galil using their 100pin breakout connector. At some point, there has to be a larger break-out point, why not make it sooner, not later down stream?
The micro/mini connectors often require either expensive tooling or high priced pre-made cables.
IMO, offering the much cheaper more practical, standard 'D' or IDC ribbon, allows the direct hookup of items like standard Opto cards and common IDC to terminal breakout's.
I believe for industrial applications, this would be a definite asset.
Al.
Albert E.
