587,982 active members*
4,021 visitors online*
Results 1 to 3 of 3
    May 2007
    380
    Y axis rails sharing the load?
    When building the Y axis, how can I help to insure that the rails will share the load, rather than one rail carrying the load while the other just loafs along?
    John
    Dec 2004
    411
    place them horizontally?
    That's what I did. The key consideration is the required Z axis clearance however if you build a longer x axis and have the y rails slightly further apart, then z axis clearance needs can be designed in.
    I believe horizontal Y axis is better than vertical but many would disagree.
    Am away for 2 wks so can't respond.
    Andy
    Drat, imperfection has finally stopped working!!
    May 2007
    380
    Andy, your right. But most DIY router tables have vertical rails, as does mine. I can see where anything less than perfect alignment will cause the Z to be carried by one rail. I guess this isn't a problem as long as the 1 rail is strong enough to support the load.
    John
  1. Linear Rails for the Z Axis
    By Bird_E in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 07:45 PM
  2. HELP selecting MOTOR size 1 AXIS 8 ft table with load 1000 lbs
    By cjchands in forum Mechanical Calculations/Engineering Design
    Last Post: 08-08-2007, 02:27 AM
  3. Add a second set of rails to X axis..need advice.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 06-01-2005, 01:11 AM
  4. Y-axis rails
    By 2muchstuff in forum Mechanical Calculations/Engineering Design
    Last Post: 04-15-2005, 04:01 AM
  5. Axis load meters?
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 10-14-2004, 02:35 AM
