588,138 active members*
5,396 visitors online*
Results 1 to 7 of 7
    Sep 2007
    44
    Unhappy Power inverter
    Hello all,
    Please, I need help ASAP. We just recieved a used Fadal CNC 88 VMC 4020.
    The power inverter, a Baldor, has an error message we can't get rid of.
    Error message: Fault Bus Overvoltage.
    I'll try to give all pertinent info. The machine was connected by certified electricians
    These are the no's I can find on it.
    Sticker states: INV -0052
    Inverter, Baldor 10HP NCL
    Replaces REM -0094, Rem-0078
    Requires INV-0004 Dual 13ohm Regen
    Cat.# Fadal 2151 Spec# FVF 1915C-31
    Any suggestions will be appreciated.
    Richard
    Dec 2003
    24220
    Usually the bus over voltage is caused by too high input voltage, or when too rapid deceleration is used and re-generation occurs.
    The first is present at all time, the second only when operating.
    Al.
    Albert E.
    Sep 2007
    44
    We found the problem. The machine came from MN, where I belive it ran on 440v, whereas, here in TX we run 220v. The machine was wired inproperly for this, though we'd been told otherwise.
    Dec 2003
    24220
    Quote Originally Posted by beartrax View Post
    The VFD told you so though
    Al.
    Albert E.
    Apr 2005
    1194
    Changing voltage is one of the primary things you look at before you even get the machine off the truck If you are having and other machines come in use a different electrician.
    To err is human...to screwup is certifiable
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Sep 2007
    44
    The electricians where hire to run cable and connect the machine to the panel, which they did. The machine seller guaranteed the machine to be wired correctly for our voltage. we had no reason to doubt this. (On this machine, there are 21 different possible electrical connections.) This seems to be only the first of many things that are not what they should be.
    900
    Lesson to be learned--- trust yourself and verify what others tell you.
  1. frequency inverter
    By visky in forum Want To Buy...Need help!
    Last Post: 09-08-2010, 11:13 AM
  2. Inverter Problems
    By mikemill in forum Uncategorised MetalWorking Machines
    Last Post: 09-03-2010, 01:30 PM
  3. Vmc 20 Inverter Replacement
    By 340 in forum Fadal
    Last Post: 02-23-2007, 10:37 PM
  4. inverter done after #9 fault
    By logos in forum Fadal
    Last Post: 03-22-2006, 03:53 PM
  5. Inverter question.
    By MrBean in forum CNC Machine Related Electronics
    Last Post: 01-07-2005, 01:51 AM
