587,852 active members*
3,970 visitors online*
Results 1 to 8 of 8
    Aug 2005
    108
    Paper cutting
    Hi all, when I try to cut paper or cardboard they take fire, which could be wrong? focal? exaust system? i m using a desktop 40wco2 laser . thank you
    Feb 2005
    469
    You need air assist. Do you have that?
    Skip
    Aug 2005
    108
    Quote Originally Posted by SkipW View Post
    Skip
    yes, but must i use nitrogen? cause i try air and the paper fire with one laser shot
    Apr 2007
    641
    Maybe you are out of focus???
    Aug 2003
    494
    How much pressure are you using?
    The hole in the end of the focus tube may be too big reducing the pressure. My setup has only about 10-15 psi bit it works good. Is your focal length more than 2" and if so it may be too far away for the air to blow out the flame.
    You may need to extend the tube or increase the pressure.
    If your desk top machine doesn't have an air assist I recommend you purchase a fairly good quality aquarium air pump (electromagnetic piston type) and strap the outlet tube close to where you cut.
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
    Aug 2003
    494
    Oh, I forgot. Are you cutting fast enough?
    If your not then you may need to speed up the cutting as this also helps to reduce the flaming.
    Aug 2005
    108
    Quote Originally Posted by MonoNeuron View Post
    yes, i think the nozzle hole is too big, i ll try a reduction and test diference pressures.
    ths for hints m8s
    Jul 2007
    78
    What settings are you using? With 40 watts you should be using a speed of 50% or more and less than 20% power.
  1. paper shims
    By 3axisrookie in forum MetalWork Discussion
    Last Post: 08-25-2008, 07:18 AM
  2. Thermal Paper
    By Smackre in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-16-2006, 04:43 PM
  3. Cutting Paper
    By greybeard in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-10-2005, 08:29 AM
  4. Model or paper space?
    By cncadmin in forum Autodesk
    Last Post: 07-02-2003, 02:26 PM
  5. paper jig
    By David454 in forum Uncategorised CAM Discussion
    Last Post: 04-18-2003, 08:59 PM
