587,396 active members*
3,690 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 131 of 587 3181121129130131132133141181231
Results 2,601 to 2,620 of 11734
  1. #2601
    Dec 2007
    37
    Here is a 65 Impala I did for a friend
    Glenn
    Attached Files Attached Files
  2. #2602
    Mar 2007
    118
    65Impala
    great job Glenn
    how'd you do it.. hand trace? or??
    Erik
    Quote Originally Posted by gadman58 View Post
    Glenn
  3. #2603
    Apr 2005
    3634
    I made a short tutorial on how to organize a DXF file to be cut in a specific order, inside LazyCam/Mach3.
    If anyone gets a chance, have a look, let me know If I left anything out.
    Thanks,
    Free DXF - vectorink.com
  4. #2604
    Aug 2005
    578
    Switcher
    Another very helpful addition to the Zone!!!
    One point also...you can also click on the chain and locate the area on the drawing then drag it (the chain) to the desired location....
    Keep em comin
    Bob
  5. #2605
    Sep 2007
    7
    I use a free DXF 2 gcode (2.5axis) converter called ACE available from http://www.dakeng.com/ace.html 236k.
    To get the order of cuts assign layers in your favourite cad program, and make the inner most one on layer 1, next one out on layer 2 and progress outward the fixings. Thus you have one layer for each priority of cutting.
    In ACE select the layers you want and assign priority 1 to layer1, 2 to layer2, and so on.
    ACE will also allow varying depths of cut. One outstanding feature is that ACE can guess if a broken chain is not meant to be broken by applying a tolerance to the gaps ie, if the broken ends are within (say) 0.01 units then assume they're joined. ACE takes no notice of the radix you used, as it gets that information from the DXF file.
    THe one drawback with ACE that irks me is the missing G81 routine.
  6. #2606
    Jun 2008
    21
    CNC plasma firering in DXF file
    Would anyone be able to help me with a firering? Plans are to make it out of cold rolled steel and would like it to be in either 4 or 6 pieces so that it can break down for easy storage:
    Need the following letters: I B W (stands for international beer weekend)
    with beer bottles on the ring. possible 3 pieces with IBW and 3 pieces with beer bottles would be GREAT
    THANKS!
  7. #2607
    Dec 2007
    37
    Quote Originally Posted by landdesign View Post
    great job Glenn
    Erik
    Erik
    This one was a trace I have a copy of scan2cad but I can't seem to make it do well with color photos still monkeying with it.
    Glenn
  8. #2608
    Oct 2005
    1238
    Oops!
  9. #2609
    Jun 2008
    21
    FIRE RING
    Thanks. Does anyone have the snap together type fire rings in DXF? Need 3 panels to have IBW (lettering) and a Beer Bottle in the other 3 panels. I have seen these somewhere but cannot find a picture to send. they hook together and store flat.
    Thanks~
  10. #2610
    Apr 2005
    3634
    blackbeard52,
    Thanks, I forgot to mention "click on the chain and locate the area on the drawing".
    templecorran,
    I havn't tried ACE, I might have to look into that, thanks.
  11. #2611
    Apr 2005
    3634
    New DXF File ---> Design 101
  12. #2612
    Jun 2007
    20
    Hello CNC ppl,
    I need help, i need a (large) dxf file of pinocchio.
    Prefered in full length. Preffered fast. Can any1 help me out here??
    *edit*
    have found one
    regards
  13. #2613
    Jun 2008
    21
    18 ga steel metal with rusty look
    What did you use on the 18 ga.mild steel to get the RUSTY look on the pumpkin? Did you use acid/vinegar to get the metal to rust? then apply a clear coat? We are doing several pieces of galvanized metal and soaking them in vinegar to get the rusty finish. When using colled rolled steel, I am wiping the metal down with vinegar but not getting the rusty look I need.
    Watt Metal
  14. #2614
    Apr 2005
    3634
    wattmetal,
    Here is the outline (dxf) of a beer bottle.
    Maybe this will get you started?
  15. #2615
    Apr 2005
    3634
    Here is the "IBW" text (dxf).
    You will need to scale this & the bottle dxf to fit your project.
  16. #2616
    Jun 2008
    21
    fire ring!
    Thanks - Switcher!!!!
  17. #2617
    Oct 2008
    I have been working on a john deere logo and cant get it to work right. can some one help or get me a good DXF file.
  18. #2618
    Aug 2004
    3215
    Quote Originally Posted by j81hatala View Post
    Well we can not post a company logo on here, but you can do like i did.
    http://www.solidworks.com/sw/product...-downloads.htm
    and finished product for my daughter.
    http://vectric.com/forum/viewtopic.p...ce91b049#p8982
    Joe
  19. #2619
    Quote Originally Posted by joecnc2006 View Post
    Joe
    you can if you've machined it for the company , distributor , or dealer ,
    thats what all the stuff ive ever posted in the past is for , i can t disclose the companies or the dealership due to privacy reasons but they did consent to me posting those parts of my portfolio on the web
    thats my story and i'm sticking with it
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  20. #2620
    Nov 2004
    27
    Dragon
    Hello, Does anyone have the dxf or at least a clearer picture of the OMAX dragon like the one in this picture?? Thanks for your help.....
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
