587,406 active members*
3,380 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help: pocket width = cutter width
Results 1 to 8 of 8
    Oct 2007
    37
    Imagine a pocket shapped like a lower case g without the circular island in the middle. The tail of the g is the same width as the cutter. Any tips on how to get the pocket tool to cut down into the narrow tail? Another way of asking the question is how would I program a closed end slot on imported 3D geometry where the slot is the same width as the cutter?
    Thanks folks...
    Mar 2005
    461
    You should use "contour" instead of pocket.
    Jul 2008
    139
    You could lie to Mcam. Tell it the tool is .001" smaller than it is.
    Apr 2003
    3578
    Without really any thought I would jump on Mastercamgurus thought. easy place to go. or some what the same thought review picture.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Oct 2007
    37
    Thanks guys. Couldn't get the Contour to work either so just fudged it with a 0.1mm "lie".
    Jul 2008
    139
    Smile
    Yup that'll do it too.
    Dec 2005
    93
    Use a smaller cutter!
    Jun 2005
    305
    Another way is to create a curve down the center of the tail.
    Turn the compensation type to OFF.
    Then Mcam doesn't care what size tool you are using.
    That's how I program letter engraving, by using the letter as a centerline contour.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
  1. timing belt width?
    By JFettig in forum Benchtop Machines
    Last Post: 01-29-2010, 12:34 AM
  2. Pulse Width
    By coop2005 in forum Automation Technology Products
    Last Post: 09-16-2008, 07:10 PM
  3. Extend width of TM1/TM2 by 1ft
    By schoobie in forum Torchmate
    Last Post: 07-17-2008, 09:07 PM
  4. Width of slat metal
    By EssentialE in forum Torchmate
    Last Post: 03-20-2008, 06:54 AM
  5. Problem with slot width
    By Angus in forum Uncategorised CAM Discussion
    Last Post: 02-04-2006, 06:51 AM
