587,193 active members*
2,444 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > problem with electrical unload!!! edm mitsubishi
Results 1 to 10 of 10
    Nov 2007
    22
    hi, I problem with electrical onload, my machine is mitsubishi DWC90H, it does not have power to cut anything, someone can help me? thanks/victor
    Dec 2005
    93
    Have you ever run an EDM before? There are 3 things to remember about EDMing.
    1. Flushing
    2. Flushing
    3. Flushing
    You must keep the dielectric in the cut in order to do any burning!
    How is your set up? Does the machine have power to the head in the burn mode?
    Give us more information on your situation. Has this machine worked in the past?
    Nov 2007
    22
    yes,was worked!
    Quote Originally Posted by DJPLAST View Post
    1. Flushing
    2. Flushing
    3. Flushing
    hi! thanks for you atention,
    if it was working before, but listen to a thunder inside the control and I stop working the unload to the wire, I belive that they can be the source of power, you know if they can be repaired? can be a transistor switching?
    Apr 2006
    The question about your EDM machine
    Quote Originally Posted by victorcnc View Post
    hi! thanks for you attention, if it was working before, but listen to a thunder inside the control and I stop working the unload to the wire, I belive that they can be the source of power, you know if they can be repaired? can be a transistor switching?
    Victor your answer unfortunately does not make sense. Is this Mitsubishi Wire EDM machine located in the US, Mexico or Canada? If it is and it is registered with us you can always contact MC Machinery Systems at 630-616-5900 and we will assist you.
    Si usted es un orador español escoge por favor opción 6 y usted será conectados con alguien que puede ayudar usted en su idioma
    Sep 2006
    126
    check 15v dc on dc unit or check all power supply
    Dec 2009
    18
    Could anyone help to check my dwc90h parameter. It start fine but system ready button do not operate. I think there is some parameter problem.
    Sep 2006
    126
    you should check alarm, no need change the parameter, because it's locked.
    Sep 2006
    126
    try press reset twice
    Dec 2009
    18
    dwc90h paramters
    I have tried everything. Could you people send me the picture of system parameters. which come when h1000 paramter is equal to 00000000100 and
    m2.press twice input. after that the screen come.could you take the picture of this screen and option parameter 1 and 2 and send it me?
    Dec 2009
    18
    dwc90h paramters
    Hi
    I have the picture of my machine parameter. could any one compare it
    with his own machine.Can anyone tell me the difference. I am uploading the pictures.
    There are some values here before machine got problem.
    Please could any one give me atleast the picture of his/her machine of this view?i will update my parameter from the picture.
    Attached Thumbnails Attached Thumbnails IMG_0697.JPG   IMG_0709.JPG   IMG_0713.JPG
  1. mitsubishi meldos 310 - dnc problem
    By mostafabagheri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2019, 06:57 PM
  2. Mitsubishi spindle problem
    By wcopley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2013, 08:58 PM
  3. spindle start electrical problem boss 10 bp
    By Minnesota HD 10 in forum Bridgeport / Hardinge Mills
    Last Post: 01-19-2008, 05:32 PM
  4. HELP! Mitsubishi cnc hobb problem
    By Jay Rad in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2007, 07:08 AM
  5. How did you unload your milling machine from the truck?
    By phantomcow2 in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2006, 08:42 PM
