588,603 active members*
10,480 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Turning off beeping at tool change
Results 1 to 14 of 14
    Mar 2008
    9
    Does anyone know how to turn off the beeping when the tool changer is in operation? On one of the Haas we have it moves along quite quickly so the beeping is minimal; however, one machine is much slower and the beeping is irritating. The service man tried to help us but he was unsuccessful.
    Thanks for any help!
    Guy
    Mar 2007
    86
    Hi Guy,
    I'm not trying to be a jerk, but I found the Haas beeper too loud even at the quiet setting. I popped open the panel and removed it. I have not missed it.
    Jeff
    Oct 2005
    114
    I put a piece of duct tape over mine, the beep is pretty low now. Darn loud from the factory.
    HAAS VF3-5 axis trunion
    Mastercam X3
    Apr 2005
    713
    I don't know about older machines, but my '07 VF-2ss doesn't beep at all during tool changes because it's not supposed to. Questions:
    -Do you have a spindle probe?
    -If yes, does the beeping only happen when changing the probe in/out of the spindle?
    -If yes, you need to spin the probe off after using it.
    Who knows, maybe mine is supposed to beep but doesn't.
    Nov 2007
    1699
    He didn't specify but I'll bet it's a toolroom mill. The beeping is the 'get out of the way' message to the operator. Enclosed machines don't need it because you can't get your hand in the way (unless you override the door hold setting).
    Greg
    Apr 2005
    713
    Gotcha. Thanks for correcting me Greg. Don't ever do it again.
    Nov 2007
    1699
    I didn't think I corrected you...just added to it.
    My TL-1 will drive you nuts on the tool changes (same thing: beep-beep, beep-beep, beep-beep).
    Mar 2008
    9
    Quote Originally Posted by Donkey Hotey View Post
    Greg,
    Yes, it is a toolroom mill and is not enclosed. However, our enclosed Super Mini Mill also beeps but because it moves so fast the beep is negligible. The toolroom is much slower and the beeping continues much longer.
    I was hoping for a code to stop it.
    Guy
    Jul 2005
    12177
    Quote Originally Posted by TeeGate View Post
    Guy
    Have you gone through the Settings and Parameters looking for 'Beep on tool change' or something like that?
    I have several SuperMinis and Minis and none of them beep during a toolchange; I can't remember if the TM3-P beeps or not.
    Mar 2008
    9
    Thank you for all the posts.
    We solved the problem by unscrewing the beeper and pushing it into the unit. We then taped over the hole and now the sound is loud enough that the operator can hear, and nobody else has to.
    Guy
    Aug 2008
    8
    beeping
    Change parameter 601 to a zero and that should take care of the beeping,
    Mar 2008
    9
    Quote Originally Posted by chuckgolden View Post
    I will give it a try tomorrow and get back to you. Thanks.
    Guy
    Mar 2008
    9
    I could not figure out how you do this. Are you referring to using "SETNG GRAPH" and punching in 601?
    Basically, I need a little more info on doing this.
    Guy
    Mar 2006
    10
    Be very careful the tool changer won't hesitate before doing a tool change with the machine set like this.
    1. Turn Setting 7 Parameter Lock to Off.
    2. Hit Emergency Stop to turn the servos off.
    3. Press PARAM/DGNOS. Key in 601, press down.
    4. Set Tool Change Delay 601 to 0.
    5. Turn Setting 7 Parameter Lock to On.
    6. Reset Emergency Stop and clear alarm.
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. how to change the passes in turning
    By joachim in forum FeatureCAM CAD/CAM
    Last Post: 10-17-2012, 06:46 AM
  3. Beeping VF-2
    By MDISolutions in forum Haas Mills
    Last Post: 08-18-2011, 10:35 PM
  4. Very slow tool change on Tool Room Mill
    By Capt Crunch in forum Haas Mills
    Last Post: 12-21-2007, 07:20 PM
  5. Beeping noise
    By dgaston in forum Mastercam
    Last Post: 09-15-2003, 07:49 PM
