587,202 active members*
2,909 visitors online*
Results 1 to 1 of 1
    May 2007
    connecting turntable
    DEAR SIRS,
    I NEED TO ASK YOU SOME QUESTIONS, PLEASE IF IT POSSIBLE ASK ME ONE BY ONE:
    I WANT TO USE MY HOT WIRE MACHINE WITH TURN TABLE. I AM USING IT WITH DESKCNC SOFTWARE. IT MEANS THAT WE CAN WORK WITH 4 AXIS INDEPENDIENT. MY MACHINE IS LIKE THE PHOTO, I DID IT BY MY SELF.
    I ALWAYS USE EPS FOAM TO MAKE DIFFERENT PIECES.
    QUESTION:
    I HAVE TURNTABLE TOO . IT USE NEMA 23 . 80 ONZ/PLUG TORQUE 1.3 AMP
    HOW CAN I CONNECTED THE TURN TABLE? IF I HAVE 2 OUTPUTS FOR THE X AXIS MOTORS AND 2 OUTPUTS FOR THE Y AXIS MOTORS TO WORK LIKE INDEPENDIENT TO CUT CIRCLES, CONES , ETC….IN EPS FOAM??????
    THE DESK CNC PROGRAM HAS X,Y,Z,A AXIS.
    I HAVE UN IDEA BUT I DO NOT KHOW IF IS RIGHT: JOIN 2 STEPPER MOTORS(2 MOTORS IN PARALLEL) TO THE Y AXIS AND CONNECTED BOTH MOTORS TO ONE OUTPUT????
    CONNECTED THE 2 MOTORS TO THE OUTPUT FOR THE X AXIS
    AND CONNETED THE TURN TABLE TO THE OTHER OUTPUT (A AXIS)?
    I HAVE THE LATHE TOO, IT USE NEMA 23 . 80 ONZ/PLUG TORQUE 1.3 AMP, I THINK IS THE SAME QUESTION. HOW CAN I CONNECTED THE LATHE TO WILL USE IN MY MACHINE FOR CUT EPS FOAM?
    THANk YOU FOR YOU POSSIBLE ANSWER,
    REGARDS
    PEDRO GAFFARO
    [email protected]
    Attached Thumbnails Attached Thumbnails cnc-3920-01.jpg   rotation4.jpg   turntable4_.gif
  1. 4-axis cutter with turntable
    By bach in forum CNC Wire Foam Cutter Machines
    Last Post: 05-15-2017, 10:50 PM
  2. HOW ADD TURNTABLE TO MY 4 AXIS MACHINE?
    By pedroenrique in forum DeskCNC Controller Board
    Last Post: 07-29-2009, 10:06 PM
  3. turntable for welding
    By DanOSB in forum MetalWork Discussion
    Last Post: 07-21-2009, 03:18 AM
  4. help with turntable
    By tallwelder in forum Welding Brazing Soldering Sealing
    Last Post: 05-19-2006, 08:12 PM
  5. Indexing turntable
    By F57887 in forum RC Robotics and Autonomous Robots
    Last Post: 02-07-2006, 08:37 PM
