Turning 4140 heat treated to R60
I am currently trying to machine some bearing races that have been case hardened to R60 .06 deep. I haven't found anything tooling wise that will machine the part after heat treat that will last longer than one part. I machine the part .02 over size with extra material on the back to help keep warp down. I then turn the .02 off to final size ( to remove warp). Then part off the final race. My inserts are usually shot after one part. I have used several different grades of inserts and even tried a pcd insert. I know that grinding is the best way to do this but the shapes of the race prevent this. Any suggestions?
No matter how good you are, there is always someone better!!!
