Originally Posted by
Richards
Gary,
Yes, the motor, if wired parallel, would give more torque; however, that torque comes at a high heat price. With four coils drawing current, instead of two coils, you'll get a lot more heat. On some Oriental Motor PK299-F4.5 motors that I recently tested (excellent motors, by the way), when wired parallel, the motors quickly stabilized at 85C. When run half-coil, the motors had a hard time hitting 65C. Granted, when wired parallel, the motors had more torque, (SQRT(2) X half-coil torque = parallel torque) but when wired half-coil, and with a 3.6:1 belt-drive transmission, the half-coil connected motors had much more torque than I could use. It proved to me that I could use the smaller and less expensive PK296-F4.5 motors next time.
