588,567 active members*
4,380 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > problem Bobcad V23 post manager
Results 1 to 8 of 8
    Jan 2009
    3
    Hello
    I'm from Brazil, and am having great difficulty in generating the code or code Nc g, because when I clicked on the tree milling tools with the right mouse button, then click on post, he should generate the code, and does not appear anything in the field post manager, is not being generated because the code of the machine, said developing a specific post for my machine, I've done several downloads from other post, and I think the problem should not be in the post, but something in the program, or I will not forget anything.
    If I make a simple design, select a basis for the play, when I click verify, it shows the path that the design will go, works perfect, only when I click post, he creates?
    Someone could help me, already called for the bobcad, I spoke with Noel, Javier, Dan Netto, and so far not found a solution, because it is difficult to talk with them, because I'm from Brazil.
    If someone can help me I am grateful, because 60 days is going to do that I am with this problem.
    att:
    Paulo Ricardo
    Oct 2006
    173
    POST
    If there is no code when you choose post try using post and save then save the file , if your code appears let me know.
    Oct 2005
    859
    Very first thing to check is that the post is actually installed.
    When Bobcad is installed it defaults to a post that is not even installed. If you attempt to select a new one you will see the list of installed posts. Go to Bobcads web sight and download one that works for you.
    http://www.bobcadsupport.com/support_bobcad.php
    Here is the direct link to V23 mill posts
    http://www.bobcadsupport.com/posts/i...dsupport/posts
    Jun 2008
    1838
    Have you checked the NC File Path setting??
    If not go to your CAM Tree and follow this.
    Open CAM Part > Right click "Milling Tools" > Left click "Current Settings" > Left click "Machine" and then look at the "window" under "NC File Path".
    If your Computer Hard Drive has the letter "C" assigned then it should show C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\NC\Mill\
    If your drive letter is "C" and the above is not correct then use the "Select" button to set the correct path.
    The same applies if you have a different letter assigned to your hard drive as BobCAD usually defaults to "C" drive.
    Hope that was clear and of some help to you.
    Regards
    Rob
    Oct 2008
    Hi Rob;
    I had the same problem that the Brazilian fellow, Your post solved the problem.
    Quote Originally Posted by The Engine Guy View Post
    If your Computer Hard Drive has the letter "C" assigned then it should show C:Program FilesBobCAD-CAMBobCAD-CAM V23NCMill
    Regards
    Rob
    Jan 2009
    3
    Thank you for your help, my problem was resolved.
    Was to make POST AND SAVE AS to occur the correct way.
    thanks for attention.
    abraços
    Jun 2008
    1838
    Quote Originally Posted by paulorockmacedo View Post
    abraços
    Hi, if you have to use POST AND SAVE AS to generate the code then it is the NC File path that needs to be reset.
    If you do the reset in my other post then you can use POST to generate the code as normal, this is correct system.
    Regards
    Rob
    Jun 2008
    30
    Didn't Work
    Regards
    Rob
    I'm having the exact same problem as the initial poster. (I have a separate thread about it.) I tied your suggestion and nothing happened. I still can not see the G-Codes.
    Bill
  1. Layer-UCS-Post manager? where is it?
    By nelZ in forum BobCad-Cam
    Last Post: 12-16-2008, 07:46 PM
  2. Problem with mach 3 or bobcad
    By elmor fudd in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2008, 09:36 AM
  3. BobCad 21 to Bandit I level3 post problem
    By bbutcher85710 in forum BobCad-Cam
    Last Post: 02-08-2007, 08:33 PM
  4. 32MP Memory Manager transfer problem
    By RoboVin in forum Fadal
    Last Post: 08-21-2006, 02:53 PM
  5. Bobcad beginners problem in Mach...
    By adryan in forum BobCad-Cam
    Last Post: 09-22-2005, 09:33 PM
