588,311 active members*
5,229 visitors online*
    Jan 2006
    461
    64 RMS Surface Finish?
    I just got my first actual machining contract today and had a question about surface finish. I am going to be making 100 small parts on the lathe and it specifies 64 rms. So the question is, what does the finish look like?
    Jan 2007
    355
    This is going to be tough to describe. A 63 finish falls somewhere between a very nice finish (32) and a "good enough for production" finish (125). The finish should be fairly smooth, no chatter.
    You might want to invest in a set of surface finish standards, which are simply a set of blocks machined to various surface finishes. These blocks can be used visually as comparators, or used to calibrate surface finish measuring equipment.
    Here's one link, there are many more (cheaper) ones out there, I'm sure.
    http://www.edmundoptics.com/onlineca...productID=2468
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Jan 2006
    461
    That is fantastic. Thank you very mucc for the info and the link. I just purchased a set at a great price. Thx again.
    Dec 2005
    3319
    THe ID of a PROPERLY refinished auto engine con rod is 50-64.
    Too smooth here and not enougt "bite" into the bearing to keep it from spinning. Too rought here and poor size control plus poor heat transfer out of the bearing into the rod.
  1. Surface Finish
    By life3970 in forum Mini Lathe
    Last Post: 11-07-2007, 07:00 PM
  2. Surface finish
    By skmetal7 in forum Mini Lathe
    Last Post: 09-10-2007, 06:56 PM
  3. Surface finish
    By chakaloso in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2007, 02:54 AM
  4. Surface finish
    By d.a.v.e in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2006, 08:35 PM
  5. 32 surface finish
    By mroy0404 in forum MetalWork Discussion
    Last Post: 05-29-2006, 03:02 AM
