588,522 active members*
7,762 visitors online*
Results 1 to 6 of 6
    Oct 2008
    4
    VF-4 Zaxis soft limits
    Ok Heres the problem.
    Often I am required to engrave useing a .04 endmill or carbide center drill.
    My machine hits it soft -z limit about a inch from the top of the table useing a collet tool holder. Is there a way to turn off the lowed z soft limit?
    I am sure there is room because I can lower the tool to the table with the wheel crank. then I get fault #318 stored stroke length.
    Dec 2008
    10
    You can in fact fudge the parameters for travel on any of your axis's. I would personally recommend against doing so. You can only get a very small amount before you start causing damage, I thinks its about .1 on x and y, not sure about z tho.
    The parameters are set by the number of encoder steps so the number to enter is dependant on your ball screw.
    Again I would recomend against messing with that, and its very odd that your handle jog allows you to travel to a distance that produces an alarm, that may actually be a problem to have looked at.
    Probably use a longer necked holder or get a extension with a small collet on the end of it.
    Jul 2005
    12177
    My suggestion is don't try it. I had a TM3P with an incorrect soft limit value in the Parameters for the Z axis and I spun the handwheel fast to bring it down to its maximum travel. It hit the hard stop and wiped out the Z axis ball screw.
    Soft limits are there for a reason...so the controller stops the travel before it hits something hard.
    Apr 2005
    713
    Sep 2007
    73
    Quote Originally Posted by rshields21 View Post
    Quote Originally Posted by Matt@RFR View Post
    I agree use a longer tool or tool holder.
    MC
    Apr 2008
    65
    If you can handle jog the z-axis lower (to the position that you need), then its not a parameter problem, there is something wrong with your program. If you are trying to move the machine past its travel you will get an alarm before it trys to move.
    There is very little travel gained by adjusting the parameters. 1/4" at the most, and if you wanted more, it would require other things be modified.
  1. Okuma soft limits
    By Carlton Jenkins in forum Okuma
    Last Post: 08-22-2012, 05:18 PM
  2. Soft limits problem????? Maybee
    By Steve-M in forum Mach Plasma / Laser
    Last Post: 12-02-2008, 08:17 PM
  3. soft limits
    By zimba43 in forum Mach Mill
    Last Post: 04-01-2008, 10:18 PM
  4. Fanuc OM soft limits reset?
    By CNC Biker in forum Fanuc
    Last Post: 04-26-2006, 03:33 AM
  5. Question about Soft Limits???
    By Dennis Fletcher in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2005, 07:07 PM
