588,166 active members*
4,503 visitors online*
    Jun 2005
    476
    Hot Pin Foam Cutter
    Something common to hotwire cutters:
    1. It is complicated to cut an inner hole without leaving an enter/exit path.
    2. CAM software rarely understands that there is no "safe Z" for rapids.
    How about solving that problem by using a 1mm diameter "hot pin" that is supported only from one side? With a solenoid to retract the pin to a "safe z", you could allow the cam software to use rapids carelessly and cut interior shapes.
    What I propose might only be applicable to the type of 2-axis foam cutter I built.
    What do you guys think? Is it feasible? How small of a diameter pin could I get away with? 1mm? 0.5mm if moving really slowly?
    Aug 2005
    437
    Interesting idea, Id like to see how it comes out, and what size pin you need for reasonable results.
    Good luck.
    Rob.
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
    Mar 2006
    474
    I wonder if heating it evenly will be a problem. It seems like the far end would be a lot cooler, resulting in tapered cuts or limited usable depth.
    Good luck, I'm looking forward to your tests!
    Jun 2005
    476
    Even heating
    Good point about the challenge of heating evenly.
    Perhaps I can use a copper pin instead of steel for better heat conduction.
    Maybe the best thing to do is simply test it. I am having fun with the hotwire cutter for now, but eventually I'll give it a go.
  1. CNC foam cutter
    By vcatalasan in forum CNC Wire Foam Cutter Machines
    Last Post: 01-06-2024, 07:29 AM
  2. CNC foam cutter located in UK
    By chris_bean in forum CNC Wire Foam Cutter Machines
    Last Post: 08-30-2008, 05:43 PM
  3. Simple foam cutter
    By venomx999 in forum CNC Wire Foam Cutter Machines
    Last Post: 02-15-2007, 06:20 AM
  4. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
  5. Foam cutter
    By paulried in forum CNC Wire Foam Cutter Machines
    Last Post: 10-30-2003, 10:58 PM
