587,672 active members*
3,166 visitors online*
Page 16 of 24 61415161718
Results 301 to 320 of 476
  1. #301
    V Carve Pro does not do 3D, but it does do V Carving. And it's a pretty full featured 2D CAM package as well. The only way to do 3D with V-Carve Pro, is to use Vectric's Cut3D to create the toolpaths. V-Carve Pro can import those toolpaths, which will allow you to mix 2D, 3D and V Carving.
    If you have the need to create 3D objects, then you need to look at Aspire, which contains all the features of V Carve Pro as well as 3D creation and 3D toolpath additions.
    You can also import all the VectorArt 3D graphics into V-Carve Pro.
  2. #302
    294
    Hey guys,
    Well I have made quite a few things using VCpro but made this tonight using phenolic...this stuff is excellent to cut!! First time and it might be my most loved material to cut.
    How many of us have taken the Vcarve file and inserted our own writing...
    A sign made for the office, 1/2" phenolic using a 60 degree V bit and a 1/4" router bit for the cut out. I cut it at about 2000 mm/min (78 ipm). I think it came out pretty darn good. Don' know why the L is a little crooked...
    I might push some caulk or that crayon type suff to add some color to the letters.
    taus
    www.cuttingedgecnc.om
    Thanks,
    tauseef
    www.cuttingedgecnc.com
  3. #303
    Nov 2007
    2466
    have fun you are there now!!
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
  4. #304
    Dec 2006
    77
    taus,
    That's cool.. Were did you find the material?
    Brian
  5. #305
    294
    Thanks guys,
    I got the material at a local Woodcraft store..they have it on closeout. It is phenolic with a formica laminate on the top and bottom. People use it as the router base plate in their router tables. Cuts really well.
    Not cheap, the piece, I think it was arouind 15"x15" was $20.00 on clearance.
    Sill I might have to go back and get more
    Here is a "my little pony" shelf I am working on for my little girl. She wanted a place they could sleep at night
    taus
    Thanks,
    tauseef
  6. #306
    Nov 2007
    2466
    oh yea!! my eleven year old is a mmember of the "pony island" networking, site
    and that is big business!!
    jim
  7. #307
    294
    I am having way to much fun....can a program really make machining so much more enjoyable? Yep it can. I love this program.
    I made this tonight, larger (now I wish I had made it even bigger It is about 18" long.
    Select pine wood, cuts really nice.
    60 degree V cut bit that is really about 55 degrees.
    5 mm depth passes at around 60 ipm cut speed.
    I than used a 1/4" router to cut it out...since I did not put a spoil board under it I used a dremel with a "router" attachment and a spiral zip blade to cut it out by hand. I than used my router table to put an edge on.
    I noted the "l" came out straight unlike the one I cut in phenolic,,,I think I was just cutting that too fast and the machine did not have time to ramp donw/up ??
    I really like it. Now I just have to figure out how to finish the pine wood- stain? Colors? ummmmm
    taus
    Thanks,
    tauseef
  8. #308
    Jan 2009
    17
    Our Project using Vectric, Meshcam, and solidworks
    We recently produced the majority of exhibits for the new Children's Museum of New Hampshire. Here is a picture of the interactive submarine made completely out of wood. Complete with 3 screen dive simulator, working para-scope with 11 lenses, a sonar and listening station. Let me know your feed back as we are working on other projects. http://i400.photobucket.com/albums/p...080523copy.jpg
  9. #309
    Nov 2007
    2466
    that is really cool!!
    i hope you will post that on vcarves forum
    jim
  10. #310
    Jan 2009
    17
    Will do
  11. #311
    294
    Awesome Work!!! That is one big display!
    taus
    Thanks,
    tauseef
  12. #312
    Sep 2005
    116
    Great work of art!!!
    Please post more pictures if you could!
    Bill
  13. #313
    294
    I love this program!!! I cut this out finding the file on Vcarve pros website...awesome!!!! I added a little to the edges....wow
    taus
    Thanks,
    tauseef
  14. #314
    Aug 2005
    597
    Looks great Taus.
    The crsip and sharp corner detail show that the machine + cutter are running very well
    Regards,
    Tony
  15. #315
    Oct 2007
    61
    How long did that take to cut?
    Thanks, nice job!!
  16. #316
    294
    I think the question is to me ???
    If so, the Harley plaque took about 30 to maybe 40 min I believe...not bad at all.
    thanks,
    taus
    Thanks,
    tauseef
  17. #317
    Feb 2008
    21
    Mick40,
    If you are asking about the V-Carve text I cut everything in about 45 min. That was the complete sign with Upper and Lower case text along with the numbers and other misc. figures. I ran it fairly slow so I would get a good quality sharp internal corner.
    Thanks!
  18. #318
    Jun 2008
    6
    Quote Originally Posted by tauscnc View Post
    taus
    Hello what software do you run the machine with ( mach 3 or something els )
    Tomas
  19. #319
    Sep 2006
    290
    Harley litho
    First try at Harley litho
    Attached Thumbnails Attached Thumbnails Harley litho web.jpg   Harley in the window.jpg
  20. #320
    Sep 2006
    290
    Where are the Samples Guys ?
    Hey! I just drug this up again ... No one is sharing , I know most post on vectric site . but would be nice to have just a gallery location so didn't have to go thru the thousands of threads on the vectric site .
    Anyways here is the Harley litho in its home and a new lady in the wood ( well she is kinda out of the woods now) :idea:
    I made a flickr account so family or who ever can see some of the stuff I do ... http://www.flickr.com/photos/17611327@N04/
    Hope you will do the same :cheers: Kent
    Attached Thumbnails Attached Thumbnails HD clock unlit .jpg   HD clock in the dark .jpg   HD clock side.jpg   After few coats satin web.jpg
