587,729 active members*
3,182 visitors online*
Results 1 to 19 of 19
    NEW G540 Kits
    Here is our new G540 Kits ( just come and in stock)
    G540 4 axis package 1PCS G540 +4 pcs KL23H284-35-4B (1/4” Dual
    shaft with a flat) Rated Currant 3.5A, 4mH Inductance, 387 oz-in + 1 pcs KL-600-48 48V/12.5A 115V /230V
    power supply)
    http://www.kelinginc.net/CNCNEMA23Package.html
    Dec 2004
    1865
    Looks like it is a nice package and I am glad to see that the motors are available seperatly for guys like me who have g251's and just need motors.
    The max voltage of 63 is close to the g540 max of 50v and should run real well.
    Have you done any testing with these motors and the g540 to see how well this package works?
    The price increase for the kit of $80+ (over the last package deal) is a little troubling, but I guess everything goes up in price.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Quote Originally Posted by TOTALLYRC View Post
    Mike
    Hi Mike
    1: You can get the motor here
    http://www.kelinginc.net/NEMA23Motor.html
    2: We have change the power supply from 48Vdc/7.3A to 48Vdc/12.5A. So the price changed $80 from the last package
    Package is here
    Dec 2004
    1865
    Thanks for the update.
    One of the things I really like about the zone is that you get fast response to questions and they are out in the open, for everyone to see.
    I also like the notation about the motors being designed for the g540. They will also then work as well for the g250/251's as they are the same drives.
    Mike.
    Nov 2008
    37
    My G540 kit has just arrived, any wiring diagrams anywhere?
    Thanks!
    Mar 2008
    3655
    That's a nice package. For something like the X2 though, (Which doesn't need 387s to power the axes) you could use three 270s for A, X, Y,
    http://www.kelinginc.net/KL23H276-28-4B.pdf
    and a 387 for Z.
    http://www.kelinginc.net/KL23H284-35-4B.pdf
    That would allow use of the KL-350-48 48V 7.3A PSU,
    and cut the total cost to $526.
    CR.
    Quote Originally Posted by rich_cree View Post
    Thanks!
    Pls check here
    http://www.geckodrive.com/upload/G54...3%20MANUAL.pdf
    Quote Originally Posted by Crevice Reamer View Post
    and a 387 for Z.
    CR.
    We will have the KL-350-48 48V 7.3A PSU in stock soon
    G540 Kits
    Mar 2008
    3655
    I appreciate that you have to sell what you have in stock, but the 85V 495 is not nearly as good a match for the 50V G540 as the 65V 387 is. The 382 is a 75V motor, so is a little better.
    For something like an X2, you could use the 4 wire. 60V KL23H276-28-4B 270s for the X and Y and the KL23H2100-30-4B 382 for the Z, (Of course you will have to adjust for the 3/8" shaft) and those should work really well.
    CR.
    Jul 2003
    586
    why? i am thinking about getting the package and all input is welcom.
    Mar 2008
    3655
    The inductance of a stepper motor determines its best operating voltage. We need to run that motor wired Bipolar Parallel, as near to its Best Voltage as possible, to get maximum power out of it.
    A small, fast motor is better than a large slow one. Ideally, we would run a 50 Volt motor at 50V, but right now there are NO perfect motors for the G540. So we need to get as close as we can, and at this time a 60 or 65V motor is about as close as we can get.
    Of course, the motors in the kit will RUN with the G540--They just will not perform as well as the 387s that are out of stock. Keling "Kits" are just arbitrary groupings. The group of parts costs the same as if you bought them individually. You can mix and match and make up your OWN kit. Just make sure that what you want is in stock.
    If you have some time, I would wait for the 387s to come back in stock.
    CR.
    Quote Originally Posted by Kelinginc View Post
    power supply)
    John,
    Have you seen our new G540 quantity discount schedule?
    Mariss
    Jul 2003
    586
    thanks for the response. i understand .
    The G540 Kits are in stock now, pls check here
    http://www.kelinginc.net/CNCNEMA23G540Package.html
    Jun 2003
    114
    Is there any nema 34 that will work with the G540?
    Mar 2008
    3655
    Quote Originally Posted by kanankeban View Post
    It would have to operate well on 50V and 3.5A wired Bipolar Parallel. So far, none that I have found.
    CR.
    CR.
    Hi all
    We have a new stepper motor in production rated at 3.5A,, 2.8 mH, Rated Torque is 318 oz-in. This one runs good at 48VDC power supply. Specification:
    http://www.kelinginc.net/KL23H2100-35-4B.pdf
    If you lower the inductance to 2.5 mH, and run at 48VDC power supply, Motor will get very hot, unless you drop your DC Voltage ( not run at 48VDC).
    Nov 2005
    35
    Wait for KL23H2100-35-4B, or buy KL23H284-35-4B now?
    Do you know when the new motors, KL23H2100-35-4B, will be in?
    The KL23H284-35-4B is rated at a higher holding torque but the new ones seem to match the 540 better.
    What is the best recommended motor for a 4' by 4' router? I'm going to be trying the new 1/2-8, 8 start acme screw.
    Dave
  1. Retrofit with G540 possible?
    By mickenordin in forum Gecko Drives
    Last Post: 01-10-2011, 07:45 AM
  2. g540
    By Scooby Doo in forum Gecko Drives
    Last Post: 05-17-2009, 07:44 PM
  3. Anyone get the G540 working?
    By Fixittt in forum Gecko Drives
    Last Post: 05-08-2009, 03:12 PM
  4. G540 PS 56V no load, is this OK?
    By jemmyell in forum Gecko Drives
    Last Post: 12-19-2008, 10:50 PM
  5. Replies: 19
    Last Post: 12-24-2005, 07:12 AM
