587,770 active members*
3,388 visitors online*
Results 1 to 8 of 8
    Jul 2007
    22
    motor failure
    Hi there,
    Where are you guy's getting parts for your lathe? I have a Craftex 7X12 that I bought used a few years ago. I replaced the brushes in it when I bought it and has worked great up until now. It looks like the armature has shorted out this time so I need a new motor. so leads on where to buy parts would be greatly appreciated.
    Kurt
    Dec 2007
    15
    All of my mini-lathe parts came from www.littlemachineshop.com
    Shipping to Canada is a bit expensive but the service and selection are outstanding.
    http://www.littlemachineshop.com/pro...1311&category=
    You might want to verify if this will work for your lathe, before purchase.
    Also you might want to check with Busy Bee to determine if you can get it cheaper through them.
    They sell the armature for mini lathe, I don't know if its the same as yours but it might be.
    http://www.littlemachineshop.com/pro...3051&category=
    May 2005
    5
    Hello Kert. You could find the fault could be the suppression capacitor fitted in side the end cap near the brushes, i had this happen to me, first i removed it to prove that was the fault then replaced it. this on a unimat-sl. 95 watt motor.
    Michael an eccentric English man living in China.
    Mar 2008
    3655
    Hi Kurt!
    Here's a link to the mini lathe parts:
    http://littlemachineshop.com/product...ast=mini+lathe
    CR.
    Jul 2007
    22
    Thanks for the reply's and links.
    My motor looks physically identical to the one at the Little Machine Shop.
    Micheal, my motor has no capacitor's in the end housing. Thanks anyways.
    Kurt
    Mar 2008
    3655
    It is possible that your commutator grooves are clogged with carbon. This will short out and not allow the motor to function. If you can gently scrape that out, you may be able to save the motor.
    CR.
    Jul 2007
    22
    Good idea,
    I will give it as try tonight.
    Kurt
    Jul 2007
    22
    Ok I cleaned between the comutator bars. No Luck. The windings are still shorted to one another but not to the shaft
    Kurt
  1. bridgport vmc hdd failure
    By jke6113 in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2008, 11:34 PM
  2. Lathe Motor Failure
    By Hackman in forum Mini Lathe
    Last Post: 09-14-2007, 05:38 PM
  3. Having a CRT failure on a ulti 2 KM-3
    By godspeedbear in forum HURCO
    Last Post: 08-27-2007, 11:57 PM
  4. Replies: 1
    Last Post: 12-28-2006, 05:20 PM
  5. Component failure
    By len in forum CNC Machine Related Electronics
    Last Post: 12-10-2005, 05:04 PM
