588,380 active members*
5,446 visitors online*
Results 1 to 16 of 16
    765
    NCPlot v2.06 beta 7 now available
    NCPlot v2.06 beta 7 is now available for download!
    www.ncplot.com/ncplotv2/NCPlot_v206b7.exe
    This version does not add many new features, but it is being released as a beta because I made quite a few internal changes to the code.
    There are a couple of new bug fixes and DNC features so please report any problems.
    www.ncplot.com
    Thanks,
    Scott
    Apr 2006
    3498
    I think NCPOT is cheap and great in simulation and backplotting.. Thanks for 30 days full trial Scott... Its really a great software..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    May 2007
    37
    Error message in beta 7
    Hi Scott,
    the 'Text to G-Code' tool brings me up the error :
    Runtime error 380
    Invalid property value
    Clicking the ok-button crashes NC-Plot.
    Richard
    765
    Richard,
    Is beta 7 the first v2.06 you installed, or did you have a previous beta installed? I've attached a registry file that will reset the settings for the text to g-code tool. Just unzip it and double click on it to update these settings. Then let me know if this clears up the error message.
    Thanks,
    Scott
    Attached Files Attached Files
    May 2007
    37
    Scott,
    I had a previous beta installed in a different directory. But clicking on your attached file solved the problem. No more errors.
    Richard
    Jan 2006
    4396
    Everything looks to be functioning properly. I like the new Tool List!!!!
    Another work of art from Scott
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2004
    150
    Toolbars?
    Hi Scott,
    Im having problems with toolbar positions not being saved properly. OS=win2k, Tried reset toolbars to see if that would make a difference and got an error..
    Keith.
    Jan 2006
    67
    Hi Scott,
    I am also unable to save the tool bar positions. Running on XP.
    Thanks,
    Dave
    765
    Thanks guys,
    Beta 7 has an old toolbar layout file, so resetting the toolbar layout loads this old file. I've attached the correct "default.tlb" which goes into the application folder at "\program files\NCPlot v2.06". Unzip and copy "default.tlb" to the application folder then in NCPlot go to "File / Reset Toolbars".
    I'm also aware that some of the toolbars will not stay where you want them. Certain toolbars seem to like to be at the beginning of the row and I haven't figured out why.
    Thanks,
    Scott
    Jan 2006
    4396
    Quote Originally Posted by MetLHead View Post
    Thanks guys,
    Beta 7 has an old toolbar layout file, so resetting the toolbar layout loads this old file. I've attached the correct "default.tlb" which goes into the application folder at "program filesNCPlot v2.06". Unzip and copy "default.tlb" to the application folder then in NCPlot go to "File / Reset Toolbars".
    Thanks,
    Scott
    Must be MS because I know it isn't you Scott
    Toby D.
    Schwarzwald
    Jan 2009
    30
    Beta 7 is no longer available?
    765
    No, v2.06 has been officially released so the next beta version will be v2.07.
    Scott
    322
    can't use 2.06
    Scott I sent you an email with my registration data.
    I have been happily using 2.04, so I downloaded 2.06. I installed it and it would not run. Now I can't reinstall 2.04 and reregister it.
    What can I do about this?
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    765
    Hi James,
    I just replied to your email...
    Scott
    322
    Problems all solved. Hard to say what they were since a reinstall of both 2.04 and 2.06 and relicensing worked this time!
    But, as always Scott Martinez was right with any and all support needed. It is the customer service that makes a TRULY great product.
    -James
    Jan 2006
    4396
    Quote Originally Posted by jemmyell View Post
    -James
    LOL, I recommend NC Plot to everyone I can for this very reason. Plus NC Plot is great for those Older Programs that you know are all hacked together by inexperienced persons.
    Plus it is great for proving macro programms.
    BTW: Scott, how is that G12/G13 comming
    Toby D.
    Schwarzwald
  1. NCPlot v2.06 beta 1 now available
    By MetLHead in forum NCPlot G-Code editor / backplotter
    Last Post: 09-08-2008, 02:14 PM
  2. NCPlot v2 beta 11 now available
    Last Post: 10-02-2007, 03:54 PM
  3. NCPlot v2 beta 15 now available
    Last Post: 11-09-2005, 03:11 AM
  4. NCPlot v2 beta 13 now available
    Last Post: 10-22-2005, 06:05 PM
  5. NCPlot v2 beta 12 now available
    Last Post: 08-21-2005, 02:23 AM
