You're right, it was confusing.
![Smile](images/smilies/smile.png)
When I said "serial saves you power" I meant the electrical kind, not mechanical. All other things equal, wiring in series would double the resistance therefor lower the current require draw...thus saving you electrical power...but at the cost of mechanical power.
I wired my 6-wire steppers in serial at first and like most people doubled the voltage to compensate. However, I was later schooled about inductance and you in conclusion you can't equal the performance of parallel so I rewired them. I wired "end to center" and I have a dangling other end wire (not literally speaking). Wish I knew about this stuff before buying these unipolars, but oh well. They still perform well.
