587,997 active members*
2,075 visitors online*
Page 1 of 3 123
Results 1 to 20 of 43
    May 2006
    202
    Possible bad encoder on X servo
    After some troubleshooting I found that the encoder on the X axis servo is not counting. I ohm checked all the wires back to the TNC 155b Heindenhain controller and they are good. My question, is there a way to check the outputs of the encoder to confirm that it is bad and not something in the TNC controller. I've attached photos of the encoder, which I believe is a light emitting diode type of encoder.
    Any help from the expects out there>
    Dave smith of Philly saiid I should ship it to Clarkson co. in IL and that it could cost up to a $1000, ouch, so if I can verify and or get a replacement I I can change it out myself.
    Ben
    Nov 2004
    3028
    If you swap this motor with another axis, and the problem follows the motor, then the problem may be the encoder.
    It can be checked with a power supply and a oscilloscope.
    Are you getting a measuring system defective error?
    Say hello to Dave Smith from me. We worked together from 82 to 87 out of the Bristol PA office.
    George
    Mar 2008
    91
    If it's a bad encoder, you can get pretty inexpensive and compatible encoders from either US Digital or from or from Renco. If it's urgent, US Digital stocks them, while sometimes it takes time to get a Renco encoder.
    Dec 2004
    1865
    When I checked my encoder, known good vs questionable, using a dvom, the voltage on the A and B would either be high or low on the good one when turning the motor very slowly by hand. On the bad one it would sometimes give a middle of the road reading. So instead of ~0v and ~5 v, I would get ~2v, IIRC, then I swapped out the encoder and in my case single to differential line driver and the problems went away.
    Of coure if you have a scope, just compare the output on a good one to the questionable one and it will be clear.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    May 2006
    202
    Quote Originally Posted by machintek View Post
    George
    George,
    That Dave Smith is quite the gentleman and was very helpful. He had me power up the machine, but not hit the start cycle, then move the table by hand, in the X axis and watch the monitor. The X axis didn't count, while the Z & Y did. I have a scope so I could check it. If you have the procedure and voltage required, I'd appreciate the assistance.
    Email is [email protected]
    Thanks,
    Ben
    May 2006
    202
    Quote Originally Posted by joejared View Post
    joe,
    Went to US digital, but couldn't find the encoder, so I sent them and email with the photos. Thanks for the help. If I had a procedure to test the encoder I could then determine what was bad and with my experience in electronics and with the help of my good friend, who also has 30+ years in Industrial electroincs, we could figure a fix.
    Ben
    Mar 2008
    91
    Quote Originally Posted by bherr View Post
    joe,
    Ben
    You're not looking for an exact match, really, just one that will fit. Both companies sell modular encoders, and you're looking for the right shaft size and encoder counts. You may have to exchange A and B, or if you require commutator tracks, you'll be limited to purchasing them from Renco. Either way, what are the specifications of your motors, including the dimensions of the encoder mounting holes and their thread sizes? Swapping axis' is the usual in field test. With an Oscilloscope you could see the outputs, which are fairly well documented. I have a mini test plug for most motors I work with.
    Dec 2003
    24220
    Before you try another encoder, find out it the encoder output is TTL or at least square wave.
    The TNC 155 may use one of the other Heidenhain formats that are low voltage or current sinusoidal.
    The Heidenhain controllers I have come across do use this format.
    Al.
    Albert E.
    Aug 2005
    1622
    Ben,
    You might call up Clarkson and see if they have a used or new encoder for that SEM motor.
    To check the encoder, either look at the machines schematics where the connector ends up on the input board or find the encoder model and look for a pinout diagram online.
    Figure out which pin does what. Power, Ground, A, B, and Z is all you will have from the looks of the terminals on the encoder there. Take note of the voltage that powers up the encoder. It could be 5v or 12v with the outputs typically just below that no more than 1-1.5v. Set up the scope, logic probe or meter range likewise.
    Since the machine should power up the device, ground the negative lead of your test equipment close by. Use the signal probe or test lead to verify supply power is getting to the encoder at each end of the cable, then while slowly turning the motor, each pin on the connector that you expect an output signal from. The A&B signals would be very close together pulses and the Z either 1-4 pulses per revolution. The Z pulses are a bit hard to find since there are so few.
    The procedure would be the same of you decide to bench test the encoder. The only difference is that you will need to supply the power and ground as that model encoder requires.
    Joe has the right idea, if you need to find an encoder on the cheap. The issue will be a different mounting and package size. Hollow shaft, PPR and voltage shouldn't be much of an issue. I'm not a fan of the inexpensive encoder from US Digital. At least get an industrial quality unit rather than one of the plastic types.....
    DC
    May 2006
    202
    Joe,
    the motor is a SEM Type MT 30Z4-61
    Max RPM =8300
    Volts=140
    Pulse Amps=50
    Tacho= 9.5
    Can you explain A vs B as I have no idea what your talking about.
    Ben
    May 2006
    202
    Quote Originally Posted by One of Many View Post
    Ben,
    DC
    One of many,
    I've looked thru my documentaion on the TNC155b and all my wiring diaigrams are in German. You wouldn't happen to have them in English?? If so can you email copies? Email is [email protected], or tell me were I can download them.
    thanks much,
    ben
    Aug 2005
    1622
    Joe,
    Max RPM =8300
    Volts=140
    Pulse Amps=50
    Tacho= 9.5
    Ben
    Ben,
    Al brings up a good point to find out what type of encoder it is. If this is not a TTL/CMOS pulse type encoder, it might be harder to check with a meter or logic probe. A scope might be your only option.
    I have had pulse type encoders that checked out fine with a logic probe, but when viewing the signals on a scope, the initial rise of the pulse was slow.
    Simply put for incremental pulse encoders. The basic outputs are 2 signals 90 degees out of phase from each other. These are commonly refered to as A pulse and B pulse signals that rise and fall as the encoder rotates. Setting still, these 2 wires/lines/signals might be any combination of high or low. This format allows the control to differentiate the directional rotation by logic of which signal goes high or low first, relative to the next change in state-an up or down count. The Z pulse is primarily used at the homing sequence as a marker pulse after finding the homing switch.
    DC
    Dec 2003
    24220
    This link shows it could possibly be sinusoidal input encoder type?
    https://filebase.heidenhain.de/doku/...b/23268625.pdf
    They also appear to have 5 connections which rules out differential type.
    Are they ROD 420 encoders?
    Al.
    Albert E.
    May 2006
    202
    Ben,
    DC
    How do you tell the difference between the TTL/CMOS pluse type?
    My schematics are all in German on the TNC155b, so its impossible for me to tell what is what for pin outputs.
    Ben
    May 2006
    202
    Al.
    Al,
    the encoders have a 10 pin molex plug with only 9 pins being used. there is no names on the circuit bd, unless its on the bottom. I'll pull the bd and check. Pulled the Bd and nothing on the other side.
    ben
    Dec 2003
    24220
    A closer check, I see a double row of 5!
    The two signals being 90° apart is how it gets the name quadrature encoder.
    Al.
    Albert E.
    May 2006
    202
    Al.
    Al,
    OK, so what does this mean and which type of encoder do you think it is????? I went to the site and couldn't find the pin out for the encoder.
    Ben
    May 2006
    202
    Encoder
    Al,
    Here's some better photos of the encoder.
    Ben
    May 2006
    202
    Al.
    Al,
    did a search on Google and came across a CNC post that you were in on about these encoders. I did another check and found that the cover had ERO 115-125 E8 on it. The Id No.on the Y axis motor was 217 900 04. there wasn't these numbers on the X axis, but figure they are the same. Would SEM still have these availalble?
    Ben
    Aug 2005
    1622
    TTL is 5v and CMOS is 12v typically. By the look of the metal disk, I'd expect just a standard optical pulse encoder, but I trust Al knows them better than I do!
    DC
Page 1 of 3 123
  1. Encoder / Servo
    By stevo1 in forum Fanuc
    Last Post: 07-10-2008, 07:06 PM
  2. gecko / servo / encoder wiring
    By shnitzel in forum Gecko Drives
    Last Post: 07-19-2007, 12:02 AM
  3. servo encoder question
    By CNC Darren in forum Servo Motors / Drives
    Last Post: 03-08-2007, 11:20 AM
  4. servo encoder placement?
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 12-01-2006, 07:46 PM
  5. servo verses dc with encoder
    By phil spanner in forum Servo Motors / Drives
    Last Post: 03-27-2006, 01:20 PM
