588,137 active members*
5,758 visitors online*
    Feb 2009
    5
    MACH 3 and XP
    Hello all, very first post here. Sorry it is under these circumstances! Any how, I have Mach 3 installed on a fresh install of XP Pro, service pack 3. The DRIVERTEST crashes the system completely, no mouse movement, no keyboard, nada. The special driver does nothing at all. I've disabled all the non-essential processes running in the back ground, still nothing.
    System specs:
    XP Pro sp3
    1 GB RAM
    2 GHZ AMD Athlon
    What's my next move?
    35538
    Feb 2009
    5
    Great! That did the trick for that problem. But it uncovered another problem! My axes are controlled by StepGenie ICs, similar to the 5804 chip. It runs fine under KCAM control, but Mach3 just makes them chatter or scream. I've tuned the motors every which way, and no luck. So, I've investigated the ICs and the docs say they can accept inputs up to 16 kHz. Since the Mach3 software starts at a baseline of 25 kHz, does this mean my axes are not controllable under Mach3?
    35538
    25Khz is the max frequency. Try increasing the pulse width in the motor tuning. Increase up to 40 if you need to and see if that helps.
  1. Configuration Mach 2 to Mach 3
    By cnc-mike in forum Machines running Mach Software
    Last Post: 11-06-2008, 02:43 AM
  2. Mach 2 Works, Mach 3 Doesn't
    By mrcosmos in forum Mach Software (ArtSoft software)
    Last Post: 07-27-2008, 09:12 PM
  3. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  4. Moving to mach 3 need exact mach 2 screen
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2005, 10:00 PM
  5. will mach 2 or mach 3 work for 4 axis cnc?
    By Runner4404spd in forum Mach Mill
    Last Post: 10-05-2005, 05:44 PM
