588,676 active members*
6,549 visitors online*
Results 1 to 6 of 6
    6
    hard turning carbide
    Hello,
    I am new to this website (tonight). I hope I am not posting this thread in the wrong section...
    Does anyone have experience in hard turning carbide? Not green carbide (before pressing), the really hard stuff... 75+ Rc... I have experience and success with nickel grades ie: CD-12N, but am having a bear of a time with micro grain carbides that do not contain Nickel.
    We are trying to hold within .0002 in. over 2+ inches of profile work. Finish must be excellent (10 rms or better). At least there are no interrupted cuts (thank goodness). Currently using PCD tipped tools (DNMA-433) and trying various toolholder geometries. Roughing eats up PCD inserts (as expected) but must be done as preforms are not very close (having to remove .015 or so per side before even thinking about finishing).
    Any suggestions and/or comments would be greatly appreciated.
    Thanks for taking the time to read this,
    Bonz
    4826
    Golly, that's a real man's definition of "hard turning": hard turning carbide Its the first I've heard of it being done in a lathe type operation. Is it better than grinding for some reason?
    First you get good, then you get fast. Then grouchiness sets in.
    Jan 2004
    3154
    Hu
    Turning probably is 10 times faster and to create the geomtry a lathe can produce a CNC grinder is 3-$500,000 easy.
    Bonz do you know what brand and grade PCD you sre using?
    www.integratedmechanical.ca
    6
    DareBee,
    Sorry to take so long to reply. Got real busy this last week. I will have to get the data on which grade of PCD is used. Using RTW Grade 3010 on CBN Tipped for hard turning steels (A-2, D-2, CPM-M4, Etc...). This works great. Even turning a part at Rc 60-62 with 17 interruptions - holding up much better than expected.
    I will send more info soon...
    Bonz
    Feb 2004
    17
    Also, does anyone know if there are options besides EDM for drilling 1/2" holes into carbide, 3/8" deep?
    Everybody starts at the bottom.
    Jan 2004
    3154
    If they are thru holes you could waterjet.
  1. A2100 Hard Disks
    By tricky in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2018, 08:33 AM
  2. Simple Carbide Grinding
    By cbcnc in forum Toolgrinding / Toolgrinding Machines
    Last Post: 08-16-2005, 03:21 AM
  3. A2100 Cincinati Hard Disks
    By tricky in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2005, 02:03 PM
  4. Carbide Cutters.
    By WilDun in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2005, 10:58 PM
  5. How deep with a .375 Carbide cutter.
    By Ken_Shea in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2004, 11:52 AM
