Hi Everyone,
This is the first time on this Forum and new to cnc. I ordered the CNC 3 Axis Package with 425 oz-in motor and KL-4030 Bipolar
Driver with 36V /8.8A Power Supply, and I'm in the process of getting it all wired up but now I have a problem.
As you see in the left side of the picture I have a 5V. power supply that shuts down every time I hook up the 5volts to the DB25. I disconnect it and it comes back on (it's an overload feature). I've checked all the wiring per there web site and all seems to wired right. I also installed the jumper wire JP1 to JP2 for the 5 volts. Has anyone else had this problem?
Also are the motors supposed to (lock-up) with the power on? I'm using Mach 3 and have followed the instructions to the "T".
