587,334 active members*
3,845 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > old MAE & Sanyo Denki stepper motors
Results 1 to 5 of 5
    Aug 2007
    Hello everybody ,
    I need some information about following step by step motors :
    1. MAE HY200 2226 0470 ACM8
    2. MAE HY200 2220 0100 ARM8
    3. Sanyo Denki Step Sin 103-770-3251
    I have tried on Google , but with no significants results.
    Apr 2008
    62
    You can find info on MAE steppers here;
    http://www.ametektip.com/index.php?o...article&id=169
    Timothy
    Dec 2008
    6
    I found this at http://sanyo-denki-online.com/
    Our simplified stock numbering system identifies each motor instantly. As an example, here is our Nema Size 34, 720 oz/in., 6 amp, single shaft, bi-polar motor. Here's how it works.
    Example for stock # 346-720-SB
    The first two digits indicate the Nema or Metric frame size.
    The third digit(s) indicates the motor's amperage.
    720= Ounce inches of holding torque rounded off.
    S or D =Single Shaft or D=Double Shaft
    U or B=Bi-polar four wire or U=Uni-polar six wire
    Cheers
    Baxy
    Oct 2004
    175
    step-syn question
    moving this reply to new thread
    Jul 2008
    Found info on Step-Syn 103-770. Hope it's helpful.
    http://www.rta-deutschland.de/pdf/103-770.pdf
  1. Step-Syn Stepping Motors Sanyo Denki
    By Shanghyd in forum Stepper Motors / Drives
    Last Post: 01-16-2011, 06:47 PM
  2. how many rpm to expect from sanyo denki stepper ?
    By mladanmar in forum DIY CNC Router Table Machines
    Last Post: 12-25-2008, 04:48 AM
  3. Need help with Sanyo Denki stepper
    By vova in forum Stepper Motors / Drives
    Last Post: 05-20-2008, 05:16 PM
  4. HELP !! Sanyo Denki stepper motors ??? what are these ones ??
    By FPV_GTp in forum Stepper Motors / Drives
    Last Post: 03-22-2007, 05:46 AM
  5. Sanyo- Denki Step Syn motors need some help on driver for
    By rollin_ballz1 in forum DIY CNC Router Table Machines
    Last Post: 03-07-2006, 03:21 PM
