588,337 active members*
4,859 visitors online*
Results 1 to 9 of 9
    Feb 2006
    1792
    block skip switch operation
    I do not have any block skip switch on my machine, so I cannot test its function. So, somebody may please clarify my doubt. Thanks for your time.
    The manual says:
    "Optional block skip operation is processed when blocks are read from memory or tape into a buffer. Even if a switch is set to on after blocks are read into a buffer, the blocks already read are not ignored"
    What exactly it means?
    Does it mean that we have to set this switch on before OSRHing (i.e., displaying on the program screen) the program?
    Or, can we set this switch on even during the execution of the program, any time before the execution has not reached the affected block (i.e., before the affected block is not pre-read)?
    Jun 2008
    1511
    Sinha,
    That is correct. If the line of code that has a blockskip on it is not read into the buffer then you can activate the blockskip button on the machine and it will bypass that line of code.
    >G1X20---line of code being executed
    X50
    /X300---if the machine has only buffered to X50 you can activate at anypoint your blockskip and the X300 will not be executed.
    Stevo
    Feb 2006
    1792
    Thanks Stevo.
    You are always willing to help.
    Jun 2008
    1511
    Your welcome anytime.
    Stevo
    2932
    What model control do you have? Your Block Skip may be a "soft switch".
    Feb 2006
    1792
    Quote Originally Posted by dcoupar View Post
    It is 0i Mate TC.
    If a soft key is available for this, it would be a new information for me.
    2932
    If you go to the OFFSET/SETTING function, then [ > ] do you see [ OPR ]? That's where the soft switches are.
    Feb 2006
    1792
    Yes, software operator's panel does appear after pressing OPR. It has 3 screens which can be scrolled by page up/down keys.
    First screen:
    MODE
    HANDLE AXIS
    HANDLE MULTIPLIER
    RAPID OVERRIDE
    JOG OVERRIDE
    FEED OVERRIDE
    Second screen:
    BLOCK SKIP
    SINGLE BLOCK
    MACHINE LOCK
    DRY RUN
    PROTECT KEY
    Third screen:
    BLOCK DELETE
    DRY RUN
    PROGRAM TEST
    AXIS INHIBIT
    PROGRAM RESTART
    I manipulated several of these settings with expected results. But no setting on the first screen works. What could be the reason?
    I believe, only those soft keys work for which there is no hard key available. Am I right? But then, at least RAPID OVERRIDE should have worked. There is no such key on my MOP. Only a feed override rotary switch is there.
    Feb 2006
    1792
    OK. I got the answer.
    The keys of the software operator's panel may be enabled or disabled with 7200 series parameters.
  1. Block Skip missing
    By Scanfab in forum Fadal
    Last Post: 03-14-2009, 05:39 AM
  2. Programming part variations with block skip
    By kmuller in forum PTC Pro/Manufacture
    Last Post: 09-18-2007, 10:36 AM
  3. Block skip function
    By Vern Smith in forum Haas Mills
    Last Post: 07-31-2007, 01:50 PM
  4. Removing the block skip /
    By Shizzlemah in forum Fadal
    Last Post: 02-17-2006, 05:01 PM
  5. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
