588,301 active members*
5,116 visitors online*
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Sep 2008
    138
    Quote Originally Posted by shimi View Post
    hi all,
    just called me as shimi. i'm still new in this forum. i have TSUGAMI Model S16 Precision CNC Automatic Lathe. it use FANUC system. yesterday i was off the main swictch board for service and calibration. and also switch off the main switch of the machine. after finish the service, i switch on the machine and i got a lot of error on the screen. why it became like that.
    310 APC ALARM : X AXIS NEED ZRN
    320 APC ALARM : Z AXIS NEED ZRN
    340 APC ALARM : 4 AXIS NEED ZRN
    317 APC ALARM : X AXIS BATTERY DOWN 1
    327 APC ALARM : Z AXIS BATTERY DOWN 1
    347 APC ALARM : 4 AXIS BATTERY DOWN 1
    350 APC ALARM : 5 AXIS NEED ZRN
    360 APC ALARM : 6 AXIS NEED ZRN
    357 APC ALARM : 5 AXIS BATTERY DOWN 1
    367 APC ALARM : 6 AXIS BATTERY DOWN 1
    490 SERVO ALARM : OVER LOAD
    454 SERVO ALARM : 5 AXIS DETECT ERR
    464 SERVO ALARM : 6 AXIS DETECT ERR
    i also don't know where the battery. can somebody help me ASAP.
    Hello
    Could you tell me model of Fanuc controller
  2. #22
    Oct 2008
    8
    Salmve, if you tell me which 7 eproms you require I maybe able to supply them.
  3. #23
    Sep 2005
    37
    Sorry for delay. I have been busy and away from net.
    Injunear, do you really have right program!
    I need series 992 version 07 eprom numbers:
    001G
    002G
    011F
    022F
    041F
    111F
    112F
    Hope this helps.
    Vekku
  4. #24
    Dec 2008
    239
    Quote Originally Posted by salmve View Post
    Mark
    Thank you for offer of help, but this problem has already solved. Bubble memory has initialise and other board attached to masterboard has tested ok.
    Main problem was 7 faulty eproms at the master. My eproms are series 992 version 07. I asked from Fanuc Sweden and they have version 08. I did not get prices yet, probably not very cheap. Suggestion of another way to get those eproms?
    Are those version changeable without problem? (sure whole set of 26 eproms)
    Vekku
    I can send you the All programmed eproms Free of cost I have , I am not using that now
  5. #25
    Dec 2008
    239
    Quote Originally Posted by greenery_fr View Post
    Hello
    This problem are due to battery attached with controller only. Put the machine on for 4- 5 hours Idle in emergency than replace the suitable Battery only in power on condition these are APC alarm I think you have the Fanuc 0 M control . If still you confused feel free to communicate me Regards , Prabhat Mishra
  6. #26
    Sep 2005
    37
    Quote Originally Posted by yours_prabhat View Post
    Thank you very much for offer of help, but problem has already solved.
    I purchased whole new set of eproms from Injunear. Thanks.
    Machine is now working condition.:wave:
    Vekku
  7. #27
    Dec 2008
    239
    Hello
    can any one send me the maintainance manual of Fanuc 6 T
  8. #28
    Jan 2010
    13
    Quote Originally Posted by duccnc View Post
    When you initialize the buble memory you must switch "BMU switch " to ON position (NOT the parameter SW to enable) it's on upper side of the master print.
    dear brother,
    i need the maintince manual of fanuc 6t-b. my machine hitachi seiki 4ne3-600
    had spindle problem its micon 8 PLC didnt generate proper voltage i need book to remove this fault
  9. #29
    Jan 2010
    13
    Hello
    I purchaced old Nakamura TMC-3 with Fanuc 6t(b). It was out of order, so i get it at resonable price. I wired it up and turn mainswitch with shaking hands. All i get was "SYSTEM ERROR 9*" *-mark is strange symbol, looks like Japanese letter. Led number 1 lit on (master PCB) I have maintenence manual for this (Thanks Jonne) and i found out that it means alarm number 600. Maintenance manual has no remarks for this alarm.
    I have read old post and found out that maybe i have to do some cleaning. First i will clean part programs, and then parameter data, and last totally cleanin of bubble memory. I have instructions for those. Is that right way? I think it is better to ask before than do something stupid, isn't it?
    I have paper named "Setting of parameters" made by Nakamura. There is parameter numbers and data 0 to 160, 1001 to 1018, 2001, 2002 2101, 2102, and 3001 to 3004. Is that enough to get machine running if clening procedure get alarm away?
    In the tape reader was tape without any marks what it is. Could it be machine parameter? But what a shame it is in two! But maybe it can repair and get reading.
    Thanks in advance
    Vekku
    dear brother,
    i also had hitachi seiki 4ne2-600 with fanuc system 6t-b i need its maintenance manual. if u had plzzzzzzzzzzzzzzzz give this manual
  10. #30
    Nov 2011
    For Fanuc manuals visit
    CNC MANUALS
  11. #31
    Aug 2011
    2517
    you wont find any old Fanuc manuals online.....only from Fanuc 15B/Fanuc 16 and onwards are available in PDF format.
  12. #32
    Re: Fanuc 6T system error
    Hate to hijack a thread but this is an emergency for me
    Hello,
    In my Mori Seiki SL1 with fanuc 6A I get a SYSTEM ERROR alarm 998 102 70 and I suppose it means the eeprom 102 and maybe line 70 because there is no eeprom 70
    I hope you can help me.I need an EEPROM for fanuc 6A version 992. The EEPROM is 102F. I only need the file because I have an EEPROM reader/writer
    Share or sell, your call
    My email address [email protected] and whatsapp +52 1 811 662 1075
    jolulank
    www.doctornumerico.com
    cnc physicians
Page 2 of 2 12
  1. Fanuc 10T system label error
    By Andy Fritz in forum Fanuc
    Last Post: 11-23-2020, 09:48 PM
  2. 998 System error on Fanuc 6M
    By david_chen in forum Fanuc
    Last Post: 12-27-2019, 08:18 PM
  3. SYSTEM ERROR 998 (Fanuc 6MB)
    By HouTX in forum Fanuc
    Last Post: 11-30-2009, 05:03 AM
  4. fanuc 6m has system error 402
    By runlean in forum Fanuc
    Last Post: 01-23-2008, 03:59 PM
  5. Fanuc 6 system error 908
    By hidivsultan in forum Fanuc
    Last Post: 06-23-2006, 02:43 PM
