588,648 active members*
5,779 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > New VF-3YT arriving in 2 weeks
Page 1 of 2 12
Results 1 to 20 of 26
    Dec 2008
    9
    G'Day all
    We are to recieve a new VF-3YT in the next few weeks and while having some experience with the Haas controler on a TL-3B Lathe, this VMC will be something quite different I'm sure. Would apprieciate any tricks or tips for this machine. Cheers
    Mar 2006
    48
    Your going to love it
    We had ours now going on 4 months.My son (18 yrs old)who just started with our company and with no machining background at all is picking this up with no problem. I also love the new controller,I thought I wasn't going to as our VF8/50 that is one year old was different.When the tech did some repairs on our VF8 he upgraded the software to the same version as the VF3YT,so it makes it easier when I or my son go from machine to machine.And having the extended travel doesn't suck either 40"X26".
    Dave
    Apr 2009
    29
    We are here for any doubts and I'm sure your local dealer also. Feel free to post any difficult about the control or send any drawings from the parts you need help about programing and tooling: [email protected]
    Thank you all for choosing Haas Automation!!
    Dec 2008
    319
    Setting 76....lock out the tool change button on the keypad.
    Jun 2008
    62
    Quote Originally Posted by behindpropeller View Post
    +1000 2nd week of having out VF2, accidently hit the tool release button and watched the probe dive from the spindle:nono: into the table.
    Sep 2004
    209
    Quote Originally Posted by Mic6 View Post
    I'd be interested to see how many machines that have setting 76 set to ON are because the operator dropped a tool. That's why mine is ON...
    Setting 76 should be ON from the factory.
    Jan 2006
    4396
    Quote Originally Posted by Armech79 View Post
    G'Day all
    This is a nice mill. Did you get the CAT40 or the CAT50??
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2006
    75
    Quote Originally Posted by Doubleddaved View Post
    Dave
    Can I ask a follow up question? I have a TM-1 that I bought in December of 2007 and I just took delivery on a new TL-1 today. Before I ordered the TL-1 I asked about getting an update to the software on my mill so that the control systems would be similar and thus easier to switch back and forth between for operators. The answer I got is that it would cost around $5,500 to update the TM-1 even though it was only a year old.
    You are saying that they just came and updated your older machine for free?
    Hercules
    2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
    Apr 2009
    29
    Settings
    Here is a list of all settings I use to change for my customers:
    16 - Dry Run Lock Out - ON
    Dry run feature can be dangerous if unproperly used. If you want to use it, so turn it OFF only for specific usage. Another point is that the key is beside Single Block one, so can be easily pressed not intentionally.
    36 - Program Restart - ON
    With this setting ON, whenever the cursor is positioned, machine will consider all features and function as if the cycle was ran since the beggining (including tool and offsets).
    76 - Tool Release Lock Out - ON
    Due to the reasons already explained by the friends.
    101 - Feed Overide -> Rapid - ON
    This way is easier an more safety to control positioning movements (G0), cause these will be controled the same way than feeding movements (by Jog Handle - and with 0 value available)
    162 - Default To Float - ON
    Safety is never too much, and now there's no risk to ignore decimal point for integer values in CNC programs (much common in metric operation, but also useful for inches)
    That's all, folks. I hope it can be useful for you!
    Dec 2008
    9
    Quote Originally Posted by tobyaxis View Post
    We thought about the 50 but it ended up bieng slightly out of our price range. I think the 40 will cover 90% of our work and we will sub out the rest.
    Dec 2008
    9
    Thanks for the imput
    Thanks to all the replies on the VF-3YT, I will sort out those settings for sure.
    We have FeatureCAM to go with it, this should be good yeh?
    Software Version Update
    hercules,
    What version of software are you running and do you have the coldfire processor?
    I just visited my HFO yesterday and asked that question of their applications engineer. I told him my machine was built in late 2007 and delivered the first week of 2008 and had the new LCD screen and version M15 05 B software.
    He told me that I could run the new software and it would take all of about 15 minutes to install it.
    Also, I checked with the HAAS Factory some time back and they also told me that my machine TM-1P with the version M15 05 B software was capable of running the new version 16 software.
    If you have that version of software you might want to give the factory a call to confirm what I have told you. If you have the correct version of software and the necessary hardware coldfired processer you should be able to run the new software.
    Then it depends on how much your HFO wants to charge you for the 15 minute change over.
    Last year they had a couple of issues with the change over process, but it is my understanding now that the conversion should work well.
    Just some information that may be of help.
    John
    Dec 2008
    9
    Quote Originally Posted by HelicopterJohn View Post
    hercules,
    John
    G'Day John, Checked with the dealer and we have the new version 16 and coldfire processor with new LCD screen. Sounds good to me! I'd say we're ready to roll.
    Mar 2009
    107
    feature cam is cool for fast jobs. I always wanted more control options. For complex production parts, Esprit, SolidCam, Mastercam, etc. Even the guys at feature cam will tell you to go bigger, Delcam powermill. When you really want total control, hand written is as custom as it gets. BS in BS out.
    Dec 2008
    9
    PowerMill looked good and we may work up to that, however I thought with our limited experience and that FeatureCam will sort our lathe jobs as well, it seemed like a good starting program.
    Jan 2006
    4396
    Did you get it with this handle?
    Toby D.
    Schwarzwald
    Dec 2006
    75
    hercules,
    John
    Thanks for replying John. I will check the software version. I do remeber reading on this board when you got your mill. I think you got yours a few weeks before I got mine so I would assume the software versions are similar.
    Hercules
    Mar 2009
    107
    I didn't purchase our 08' vf3 with the remote jog handle. How much would this new jog handle cost as an after the fact add-on? Ballpark estimate?
    thanks
    Jan 2006
    4396
    Quote Originally Posted by crabbass View Post
    thanks
    No idea. You would have to call your local HFO.
    Toby D.
    Schwarzwald
    Jun 2008
    62
    Hey Toby, what's that manifold on the back wall of your machine?
Page 1 of 2 12
  1. Anodizing parts weeks or months after machining
    By jkujawa in forum Material Machining Solutions
    Last Post: 09-13-2008, 05:40 PM
  2. This weeks quiz question
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 01-13-2008, 02:35 PM
  3. Im Waiting 4 Weeks For A Transformer
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 08-25-2004, 08:52 PM
  4. After 2 weeks, and a few switches, I'm Done!
    By musicmkr in forum DIY CNC Router Table Machines
    Last Post: 07-06-2004, 08:29 PM
