603,362 active members*
3,423 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > E-stop and Fault indicator HELP
Results 1 to 2 of 2
    Oct 2006
    17
    Hello
    i was reading the viper manual, and i found this :
    A small 12 volt reed relay can be driven by the stop output to allow you to use a N/C
    Estop connection. Put a reverse diode across the relay coil to suppress kick back.
    Can somebody pass me a detail diagram of how to do this???
    Mar 2005
    5
    I had the same question and ran across an answer related to something else. If you go to this link http://www.kpsec.freeuk.com/trancirc.htm and scroll down to where it says using a transistor as a switch, it also talks about using a relay and placing a diode across the coil to avoid the high voltage spike when the power turns off to the relay coil. Hope this helps.
    JD
  1. EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 06:05 PM
  2. Best Coaxial indicator to buy?
    By aaron p in forum Community Club House
    Last Post: 03-05-2009, 08:30 AM
  3. Servo fault at pgm stop
    By pommac in forum Fanuc
    Last Post: 05-25-2007, 12:58 PM
