588,340 active members*
5,661 visitors online*
Results 1 to 11 of 11
    Jul 2005
    340
    G42 correction problem
    Hi All ,
    I got troubles with the correction with this profile :
    Code:
    T2 M06
    G00 X8. Z1. M08
    G42
    G01 Z0 F0.15
    X10.2 K-0.6
    Z-16.527
    X9.6 Z-17.717
    Z-17.9
    X18. K-0.2
    Z-27.
    G40
    X20. M09
    the profile should looks like without correction , but with makes an strange undercut - anyone knows why ?
    the tool is radius 0.4mm and tip 3.
    __
    Peter
    4826
    I'm not sure I understand the K values in your code, but one thing to check is that you need to command an XZ point that is off the part profile at the end of the cut. This lead off point should probably be on the same line as the G40 command.
    First you get good, then you get fast. Then grouchiness sets in.
    Dec 2008
    3142
    I understand the K-value being a incremental move forming a chamfer
    but putting the G40 where it is is bad, it is cancelling the tool nose radius, and will gouge the part by whatever amount you have set in the comps page
    As HuFlungDung says
    Code:
    Z-27.
    G40 X20. F1.0
    M09
    Just make sure that the X-diameter move off the part is more than twice the tool nose radius.
    G40 X19. F1.0 ( is the closest X for R0.4 tip )( tool moves X0.2 on the G40 line)
    Jul 2005
    340
    it is an outside profile , and my problem isn`t at the end of the profile , look at the photos, the first one is without the correction , and the part should look smillar to this , the second photo is with the G42 correction, and there is a problem, the third photo is a zoom to that place.
    Attached Thumbnails Attached Thumbnails IMG_4689.JPG   IMG_4690.JPG   IMG_4692.JPG
    Dec 2008
    3142
    The pictures help
    Seems to be a compensation error, your profile does not take into consideration of the R0.4 tip, run it thru using R0.0
    If you have access to a CAD system, create the profile, offset this profile by 0.4, this is path the tool radius centre-point should be following,
    It can't get to do the little taper ending at X9.6 before hitting the Z-17.717
    wall
    Adjust the u"cut profile to have a flat, that you know the tool tip will touch
    or use a smaller tip radius
    Code:
    G01 Z0 F0.15
    X10.2 K-0.6
    Z-16.527
    X9.4 (Z-17.717)
    Z-17.9
    X18. K-0.2
    Z-27.
    G40
    X20. M09
    Jul 2005
    340
    You`re right , there was too small flat place there , I`ve made a mistake reading the undercut parameters by a 1mm , if I changed the point correctly then was OK .
    Thanks for getting me on the right track.
    __
    Peter
    Dec 2008
    3142
    Wielkie,
    solved in 7 hours
    Dopóki następnym razem
    Jul 2005
    340
    Wielkie,
    solved in 7 hours
    was that on-line translated ? I don`t get the point. And not 7hours , I didn`t solved this at the time I was writing the post.
    Apr 2009
    11
    Don't we need a T0202 at the beginning to invoke the TNR?
    Dec 2008
    3142
    Depends,
    If you progran to the TNR centre, then you do not have to use T0202, as the value of the radius woud have to be zero.
    on the other hand, you can program the path to "fudge" TNR in the profile, (as pit202 has done ) and then put TNR in the startup
    TNR is not critical in facing or diameter turning, it is necessary on tapers and tightly toleranced radii
    Sometime using TNR on a simple manually programmed profile can lead to thinning hair.
    Jul 2005
    12177
    Quote Originally Posted by Superman View Post
    ...Sometime using TNR on a simple manually programmed profile can lead to thinning hair.
    Or big piles of it on the floor and head marks on the nearest concrete wall.
    But once you have it sorted out it is so useful!!
  1. Correction question
    By majstor76 in forum G-Code Programing
    Last Post: 02-13-2009, 11:02 PM
  2. G-code for a correction
    By seunao in forum G-Code Programing
    Last Post: 12-10-2008, 02:29 PM
  3. In-Cycle tool offset Correction
    By wazzoo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2008, 08:56 PM
  4. Taper correction help
    By OKThumper in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-27-2007, 01:32 AM
  5. NOTES ON BACKLASH CORRECTION IN Mach3 1.90.004
    By chris59 in forum Machines running Mach Software
    Last Post: 05-09-2007, 06:00 PM
