587,775 active members*
3,136 visitors online*
Results 1 to 7 of 7
    May 2003
    15
    Question How to mirror GCode file?
    Hi all,
    Well I have managed to find and run the script to go from a Eagle board file to Gcode. Now the only problem I have is how do I mirror the GCode? The program works fine for the top copper but I need to mirror the bottom to have the traces in the correct orientation.
    Thanks for your help!
    Albert
    May 2003
    146
    Assuming you disnt generate the code from a CAM system (in which case mirroring in the CAM system and reposting would be easiest), and assuming your control wont do it... Use an editor such as cimco, editcnc (you can search for free downloads or 30 day trial versions of these editors) they have a function that does this automaticaly.
    If you are simply miroring about the X axis, all non-zero X values and I values get the sign changed from positive to negative or vice versa. The editors I mentioned also have a backplot feature that will display graphicaly the edited toolpath.
    Try this link
    http://www.editcnc.com/cnc-programming.html
    CAM teh "left ... left ... left . right . left"
    Wee aim to please ... You aim to ... PLEASE.
    Apr 2003
    361
    In Eagle CAM, set the mirror option ON when doing the bottom side. This will automatically mirror your trace.
    Another way is to reverse the direction setting in your CNC software; that how I do it if I can do it at source application.
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
    Jun 2003
    18
    I agree with CAMmando. Just follow his link and the rest should be history.
    no problem!
    Jun 2003
    7
    Mirror
    Try G51 X0 Y0 I-1000 J-1000
    This will scale around point X0 Y0, with a scale factor of 100% (full size) and the - (minus sign) means it will mirror it in this plane.
    So to mirror in X but not in Y use I-1000 J1000. Or just leave the J out. G51 X0 I-1000
    Use G50 to cancel G51.
    Atom.
    Apr 2003
    372
    There is also a very basic way that I have done and tested before in word pad.
    Select Search and Replace from the menu.
    Check match whole word.
    Find X-
    Replace with V$
    Then find X
    Replace with X-
    Then find V$
    And replace with X
    Do this also with your I values in arcs
    FYI this is a great way to change the axis integers if you are wishing to convert a Z plane program to an X or a Y plane program on a universal milling machine.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    507
    Kookaburra,
    Mighty interesting! Haven't thought doing things this way. Normally i do mirroring, rotation etc on the machine....that's the nice thing of wire eroders, but if the machine can't do it, well.....
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
  1. How do i get my autocad file onto mastercam?
    By EdE in forum Uncategorised CAM Discussion
    Last Post: 02-23-2011, 06:54 AM
  2. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  3. Boot disk for EZ-Track DX, batch file?
    By mmm2003 in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2007, 06:47 PM
  4. File Extensions in PFE
    By E-Stop in forum Mastercam
    Last Post: 06-25-2004, 12:53 PM
  5. AutoCad 2000 Missing .dll file
    By E-Stop in forum Autodesk
    Last Post: 05-30-2003, 05:43 PM
