587,258 active members*
2,800 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Recommendations for R8 spindle taper regrinding
Results 1 to 3 of 3
    Oct 2006
    15
    I would like to get my R8 spindle taper reground. Does anyone have some contacts they would like to share?
    Thanks - Kris
    Feb 2007
    1084
    Any ID grinding shop can do it. It's the simplist taper to grind, you just have to find the specs for the angle to give the machinst, tell him to "just dust it".
    Other than that, you can contact a repair shop, off the top of my head,
    http://www.centerline-inc.com/servic...pair/index.php
    http://www.setcousa.com/index.cfm?fu...FQOIFQodchGvJQ
    http://www.pba-spindles.com/
    MC
    May 2005
    66
    The Wells-Index mill company will regrind any knee mill spindle, and also offers bearing replacement. They typically run adds on Ebay selling the regrinding service.
    If you have this done locally, you want it done with the spindle mounted in the quill so any bearing misalignment is taken care of, don't have it done just using the bare spindle. Like I did back before you could get good info like this off the internet. Mine still came out pretty good though.
    Paul T.
  1. Spindle Recommendations
    By MayanArch in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-02-2009, 04:03 AM
  2. Has anyone got the 30-taper spindle?
    By digits in forum Tormach Personal CNC Mill
    Last Post: 07-24-2008, 03:17 AM
  3. 5 Hp Spindle Recommendations
    By skypoke in forum DIY CNC Router Table Machines
    Last Post: 07-01-2008, 01:53 AM
  4. Spindle recommendations
    By seansear in forum DIY CNC Router Table Machines
    Last Post: 09-02-2006, 05:27 AM
  5. Regrinding spindle taper hole
    By Ch_Irawan in forum Mechanical Calculations/Engineering Design
    Last Post: 03-12-2006, 09:43 PM
