587,180 active members*
3,781 visitors online*
IndustryArena Forum > CAM Software > Surfcam > SurfCam Post -repeat tool header info
Results 1 to 18 of 18
    Sep 2005
    28
    I want the Surfcam mpost to output the toolheader information for each toolpath in an operation list, even if it repeats the same tool. This way I wouldn't have to post multiple times then copy and paste together, just to get the tool header per path. It would then be easier to delete the paths out of an operation that I don't need.
    Sometimes when I am proving out some simple 2d programs I am using the same tool for a lot of different paths and I will rerun and tweak until I like what I have. It would be easier to jump to the next piece of code or path if it has the tool header info ready per each path.
    I have done a good amount of editing to my posts for my Haas but haven't been able to figure this one out. I am hoping this can be done. I do understand Haas has a on/off feature that reads the tool info if jumping into the middle of a program. I would still like the NC code to have the tool info per individual path. Control memory and file size is not an issue.
    If anyone knows this one and can share, Thank you in advance!
    Robert Flores
    MMTech 231-632-6669
    below is a sample of what I would like the code to look like. I posted this 3 times and then copied and pasted the 3 progs together. Typically I have 5 to seven paths per tool and up to 10 tools. The header at the top of file allows a quick jumpto individual paths with cursor/dwn to M99 call.
    Any additional comments are appreciated.
    O777 (FORWARD CONTROL LINKAGE)
    G54 G17 G90
    M99 P3 (T3 .50 DIA CARB RGHR -0.8750)
    M99 P32 (T3 .50 DIA CARB RGHR )
    M99 P33 (T3 .50 DIA CARB RGHR )
    M99 P100 (END PROG POSITION)
    N3
    N31
    G90 G40 G80
    T3 D3 M6 (T3 .50 DIA CARB RGHR -DR AT LOC)
    /M8
    G90 G0 X0. Y0.
    G43 H3 G0 Z0.2
    S2000 F12.0
    M3
    G0 X0. Y1.65
    G0 Z0.3
    G0 X0. Y1.65
    G40
    G73 X0. Y1.65 Z-0.3 Q0.09 K0.09 R0.1 P0.03 F2.4 G99 (MAY RETURN TO -R PLANE)
    G80
    G0 Z-0.3
    X0. Y0. Z0.3
    G40
    G73 X0. Y0. Z-0.863 Q0.09 K0.09 R-0.463 P0.03 F2.4 G99 (MAY RETURN TO -R PLANE)
    X0.0743 Y-0.8493
    G80
    G0 Z0.3
    N3
    N32
    G90 G40 G80
    T3 D3 M6 (T3 .50 DIA CARB RGHR)
    /M8
    G91 G41 G1 X-.02 F100.
    G90 G0 X0. Y0.
    G43 H3 G0 Z0.2
    S2000 F12.0
    M3
    G0 X0. Y0.
    G0 Z0.2
    G0 Z0.1
    G1 Z-0.875 F12.0
    G3 X0.27 I0.135 J0
    I-0.27 J0
    X0. I-0.135 J0
    G0 Z0.2
    G91 G40 G0 Y.05
    G90
    N3
    N33
    G90 G40 G80
    /M8
    G90 G0 X1.015 Y-0.0285
    G43 H3 G0 Z0.2
    S2000 F12.0
    M3
    G0 X1.015 Y-0.0285
    G0 Z0.2
    G0 Z0.1
    G1 Z-0.7 F12.0
    G3 X0.9834 Y-0.0567 I-0.0017 J-0.03
    G2 X0.6837 Y-0.7091 I-0.9834 J0.0567
    G3 X0.6761 Y-0.7293 I0.0173 J-0.018
    G1 X0.6858 Y-0.8401
    G2 X0.3488 Y-1.3197 I-0.4532 J-0.0397
    X-0.1144 Y-1.3602 I-0.3488 J1.3197
    X-0.5295 Y-0.9465 I0.0381 J0.4534
    G1 X-0.5392 Y-0.8356
    G3 X-0.5502 Y-0.817 I-0.0249 J-0.0022
    G2 X-0.7607 Y0.6258 I0.5502 J0.817
    G3 X-0.755 Y0.6416 I-0.0193 J0.0158
    G1 Y1.525
    G2 X0. Y2.28 I0.755 J0
    X0.755 Y1.525 I0 J-0.755
    G1 Y0.6416
    G3 X0.7607 Y0.6258 I0.025 J0
    G2 X0.9834 Y-0.0567 I-0.7607 J-0.6258
    G3 X1.0116 Y-0.0884 I0.0299 J-0.0018
    G0 Z0.2
    G91 G40 G0 Y.05
    G90
    N100
    M98 P89995 (EXIT SUB PROG -EDIT AT MACHINE)
    (/M9 )(COOLANT OFF)
    (M5 )(SPINDLE OFF)
    (G91 G0 Z3.0)
    (G91 G0 X0. Y0.0 )(EDIT AS NEEDED)
    (G111 G90 G40 G80 G0 X0. Y0. Z0.0)(ABS CANCEL ALL)
    M1
    T3 M6
    M30
    Mar 2005
    10
    Hi MMTechi,
    When we use the same tool twice, we add to the tool number by multiples of 100: like tool 25 , tool 125, tool 225. In the post where T is declared we have : T >2 Mod 100
    When the program posts, they're each changed to tool 25. Is that what you need?
    nick.
    Sep 2005
    28
    I tried what you suggested but that is not quite what I am looking for. I still either edit in my operations list or in the nc code, and I use/have a 10 pocket tool change, so the numbers don't always come out right. I wonder if the Surfcam post can be forced to output a tool call/m6 for every toolpath in an operation list?
    Oct 2008
    50
    Quote Originally Posted by NICK REESE View Post
    Hi MMTechi,
    nick.
    A+ on that, that comes in handy when you want to do a dummy toolchange.
    I also use If/Endif on my lathe post. Say I'm using T1 to face/turn, I will program the face as T1 and the turn as T101 and it will give me a dummy toolchange. That way if you dont have to rerun everything.
    ToolChange
    IF [Tool] < 100
    M9
    G28 U[0] W[0]
    M1
    Endif
    IF [Tool] > 100
    Set [Tool] to [Val10]
    Endif
    N[Block]
    Comments
    G0 T[Tool] t[Lcomp]
    G50 S2000
    G[FeedType] G[SpeedType] S[Speed] M[Direct]
    G0 X[V] Z[H]
    M[Cool]
    G4 X1.5
    Set [Val10] to [Tool]
    End
    Results:
    N10
    (CNMG432 1/32R)
    (FACE LV./.005)
    G0 T01 01
    G50 S2000
    G0 G96 S400 M3
    G0 X3.1 Z0.1
    M8
    G4 X3.
    G0 Z0.005
    G1 X-0.0624 F0.009
    G0 Z0.05
    X3.1
    N20
    (CNMG432 1/32R)
    (TURN OD)
    G0 T01 01
    G50 S2000
    G0 G96 S400 M3
    G0 X3.1 Z0.05
    M8
    G71 P1000 Q1100 D1000 U.02 W.005 F0.009
    N1000 G0 X1.919
    G1 Z0.0017 F.009
    X1.999 Z-0.0383
    Z-0.125
    X2.9234
    N1100 X3.0258 Z-0.1762
    M9
    G28 U0 W0
    DANGER ZONE - HARD HAT REQUIRED!!!!
    May 2007
    71
    How about these kinds of output?
    O1
    (T1 D25. D=0 ENDMILL CR=0 F160.0 FZ80.0 S800)
    (T2 D10. D=0 CENTER CR=0 F500.0 FZ80.0 S2500)
    (T3 D2.5 D=0 DRILL CR=0 F250.0 FZ500.0 S2500)
    (T4 D4.2 D=0 DRILL CR=0 F250.0 FZ250.0 S2500)
    (T5 D5. D=0 TAP CR=0 F640.0 FZ250.0 S800)
    (T6 D21. D=0 DRILL CR=0 F150.0 FZ640.0 S700)
    (T7 D20. D=0 ENDMILL CR=0 F200.0 FZ100.0 S1000)
    (T8 D20. D=0 ENDMILL CR=0 F200.0 FZ100.0 S1000)
    G17 G40 G80 G49
    G91 G28 Z0
    N1
    M6 T1
    G90 G54 G0 X-98.75 Y-20. M3 S800
    G43 Z100. H1 M8
    G0 Z5.
    G1 Z-3. F80.0
    X-80.
    Y0 F160.0
    X-31.
    Y-44.
    X-80.
    Y-20.
    X-88.75
    X-70. F80.0
    Y-10. F160.0
    X-41.
    Y-34.
    X-70.
    Y-20.
    G0 Z100.
    X-60. Y-1.25
    Z5.
    G1 Z-3. F80.0
    Y-20.
    X-51. F160.0
    Y-24.
    X-60.
    Y-20.
    G0 Z100.
    X-98.75
    Z2.
    G1 Z-6. F80.0
    X-80.
    Y0 F160.0
    X-31.
    Y-44.
    X-80.
    Y-20.
    X-88.75
    X-70. F80.0
    Y-10. F160.0
    X-41.
    Y-34.
    X-70.
    Y-20.
    G0 Z100.
    X-60. Y-1.25
    Z2.
    G1 Z-6. F80.0
    Y-20.
    X-51. F160.0
    Y-24.
    X-60.
    Y-20.
    G0 Z100.
    M5
    M9
    G91 G28 Z0
    G49
    N2
    M6 T2
    G90 G52 G0 X-10. Y-7. M3 S2500
    G43 Z100. H2 M8
    G81 G98 X-10. Y-7. Z-3. R3. F500.0
    Y-37. R3.
    G80
    G0 X-24. Y-22. Z100.
    G81 G98 X-24. Y-22. Z-7.8 R-3. F500.0
    X-50. R-3.
    X-76. R-3.
    G80
    M5
    M9
    G91 G28 Z0
    G49
    N3
    M6 T3
    G90 G52 G0 X-24. Y-22. M3 S2500
    G43 Z100. H3 M8
    G73 G98 X-24. Y-22. Z-19.751 Q3. R-3. F250.0
    X-76. R-3.
    G80
    M5
    M9
    G91 G28 Z0
    G49
    N4
    M6 T4
    G43 Z100. H4 M8
    G83 G98 X-10. Y-7. Z-20.262 Q3. R3. F250.0
    Y-37. R3.
    G80
    M5
    M9
    G91 G28 Z0
    G49
    N5
    M6 T5
    G90 G52 G0 X-10. Y-7. M3 S800
    G43 Z100. H5 M8
    G0 Y-37.
    M5
    M9
    G91 G28 Z0
    G49
    N6
    M6 T6
    G90 G52 G0 X-50. Y-22. M3 S700
    G43 Z100. H6 M8
    G83 G98 X-50. Y-22. Z-25.309 Q3. R-3. F150.0
    G80
    M5
    M9
    G91 G28 Z0
    G49
    N7
    M6 T7
    G90 G52 G0 X-50. Y-22. M3 S1000
    G43 Z100. H7 M8
    G0 Z-1.
    G1 Z-10. F100.0
    Y-27.9 F200.0
    G3 I0 J5.9
    G1 Y-22.
    Z-14. F100.0
    Y-27.9 F200.0
    G3 I0 J5.9
    G1 Y-22.
    Z-16.5 F100.0
    Y-27.9 F200.0
    G3 I0 J5.9
    G0 Z100.
    M5
    M9
    G91 G28 Z0
    G49
    N8
    M6 T8
    G43 Z100. H8 M8
    G0 Z-1.
    G1 Z-16.5 F100.0
    Y-28. F200.0
    G3 I0 J6.
    X-46.465 Y-26.536 I0 J5. F100.0
    G0 Z100.
    M9
    G91 G28 Z0 M5
    M30
    Oct 2006
    21
    PHP Code:
    O1
    (T1 D25D=0 ENDMILL CR=0 F160.0 FZ80.0 S800
    T2 D10D=0 CENTER CR=0 F500.0 FZ80.0 S2500
    T5 D5D=0 TAP CR=0 F640.0 FZ250.0 S800
    T6 D21D=0 DRILL CR=0 F150.0 FZ640.0 S700
    T7 D20D=0 ENDMILL CR=0 F200.0 FZ100.0 S1000
    T8 D20D=0 ENDMILL CR=0 F200.0 FZ100.0 S1000
    G17 G40 G80 G49
    G91 G28 Z0
    N1
    M6 T1
    G43 Z100
    H1 M8
    G0 Z5
    G1 Z-3. F80.0
    Hi sinderal, may I ask a question,
    how can you do that on Surfcam mpost to output the toolheader information for each toolpath
    May 2007
    71
    Talking
    Hi Torro:
    It must do some work for those! Attached please find the post file which I wrote before. You may modify it per your requirement! I am using Metric unit, so please modify all the register format to Inch format.
    Attached Files Attached Files
    Oct 2006
    21
    Appreciated your're help Thanks
    Sep 2005
    28
    surfcam output
    Hi Sinderal,
    Thankyou for your help, I like what you have in your post and am going to try and utilize some of what your post can do into my own. Where can I read more on how to do the file insert and the sxxx series code and tool info changes in the post? Pretty good work!
    This however is not quite what I was looking for. In the surfcam operations manager, when you select an operation (not just an individual toolpath) to post out, surfcam does you the "favor of not" putting a new tool header in the nc program if the same tool number is used on the next tool paths. I actually want the tool header posted out again even if the next path is the same tool (I do a lot surface 3d point to point programs, below is short prog just for discussion). I hope I am making myself understandable and hopefully you have a method. I would be glad to speak with you if it would be ok to contact you or you are welcome to call me.
    Thank you again for everyones help.
    Robert Flores
    MMTech 231-632-6669
    below is a the unedited output of the my surfcams posted list of individual toolpaths, NOTICE the comments separate the individual toolpath ( I want the full TOOLCHANGE header posted for each toolpath, even if same tool, not just the comment)
    G54 G17 G90
    N3
    G90 G40 G80
    T3 D3 M6
    (T3 .50 DIA CARB -PLUNGE MILL DR LOCATION)
    G43 H3 G0 Z0.2
    S2000 F12.0 M8
    M3
    G0 X0. Y1.65
    G99 G73 X0. Y1.65 Z-0.3 Q0.09 K0.09 R0.1 P0.03 F2.4
    G80
    G0 Z.3
    (T3 .50 DIA CARB -MILL HOLE DIA PROFILE)
    G0 Z0.1
    G1 Z-0.875 F12.0
    G3 X0.27 I0.135 J0
    I-0.27 J0
    X0. I-0.135 J0
    G0 Z0.2
    (T3 .50 DIA CARB -MILL PART PROFILE)
    G0 X1.015 Y-0.0285
    G0 Z0.1
    G1 Z-0.7 F12.0
    G1 X0.6858 Y-0.8401
    G1 Y1.525
    G1 Y0.6416
    G0 Z0.2
    N100
    M30
    This is what i would like surfcam to create, then I can easily rerun any of the pieces of code as needed even if in middle of a large program.
    G54 G17 G90
    N3
    G90 G40 G80
    T3 D3 M6
    G43 H3 G0 Z0.2
    S2000 F12.0 M8
    M3
    G0 X0. Y1.65
    G80
    G0 Z.3
    N3
    G90 G40 G80
    T3 D3 M6
    G43 H3 G0 Z0.2
    S2000 F12.0 M8
    M3
    G0 Z0.1
    G1 Z-0.875 F12.0
    G3 X0.27 I0.135 J0
    I-0.27 J0
    X0. I-0.135 J0
    G0 Z0.2
    N3
    G90 G40 G80
    T3 D3 M6
    G43 H3 G0 Z0.2 M8
    S2000 F12.0
    M3
    G0 Z0.1
    G1 Z-0.7 F12.0
    G1 X0.6858 Y-0.8401
    G1 Y1.525
    G1 Y0.6416
    G0 Z0.2
    N100
    M30
    Oct 2009
    13
    MMTechi,
    Hello again,
    I may not have been clear the 1st time. In the 1st operation, you have tool number 3. In the 2nd operation, change the tool number from 3 to 103. In the 3rd operation change the tool number to 203. (You don't have to change the length offset or the diameter offset numbers) In the postform.m file, add to the declaration of T at the top to make it "T >MOD 100" When you post the program you will get 3 operations, each with T3.
    If you use spost instead for posting, I can't help you.
    Good luck,
    nick.
    Sep 2005
    28
    Hi Scallops,
    Thanks for your reply, I tried your suggestion in my postform.m file but it doesn't output in the format style you describe. maybe you could copy/paste your post here and I will post a program through your post file to see if it will work for me.
    Just curious but will this make surfcam repost the tool header even if it is the same tool used again on the next tool path or will your post assign a new number only after that tool is used again but after a different tool is used in between paths
    my email is [email protected]
    or maybe we can talk 231-632-6669
    Jan 2010
    99
    bumping an old thread here, but i think i have an easy solution to the original question...
    quick aside; sanderal, great post! i've not seen any documentation for the "file" functionality you are utilizing, which has many other potential uses as well (an offsetting program at the bottom of the posted program to offset used tools... etc
    back to the OP's question, use this:
    Code:
    Upon Every [DComp]
    '( OPERATION ' j[block] ' )'
    '( TOOL CHANGE CODE HERE? )'
    End
    with:
    Code:
    j >4 ""                   # Operation #
    Sequence#s N 0 1 1        # block Char-Freq-Incr-Start
    note: i don't use 'block' otherwise... if you do you need a better way to track which operation it is... but with this you'll see where it inserts the code (after rapid plane, before xy move, but modal so you'll want to code that in)
    hope this helps... if not for OP at least for someone who searches and finds this... and if anyone is interested i can post the whole post, but my MO is handle the differing code at the machine in the macros (mainly the M6 macro) so the post will seem simplistic, ie (example code, do not run (my M6 macro sets everything... absolute, rapid, no offsets, AI off then back on, home z, maybe move xy, coolant off, etc...):
    Code:
    O0001 (05_FAM_TOP_ENCLOSURE_152TEST)
    POPEN(11.57.52 PM 6/28/2011)
    DPRNT[//START*05_FAM_TOP_ENCLOSURE_6152984A-01/05_FAM_TOP_ENCLOSURE_152/TEST]
    PCLOS
    ( OPERATION 1 )
    M6T3
    M1(TOOL3 0. CHAMFER MILL)
    G54X-0.2149Y-1.8404M3S12000
    G43Z1.H3
    /M8
    T11
    G0Z0.333
    G1Z0.1192F60.0
    G1Y1.8154
    G0Z1.
    ( OPERATION 2 )
    X0.1Y0.1S5500
    G81G98X0.1Y0.1Z-0.13R0.1F10.0
    G80
    ( OPERATION 3 )
    N11M6T11
    M1(TOOL11 0.0995 DRILL)
    G54X0.1Y0.1M3S6250
    G43Z1.1H11
    /M8
    T3
    G83G98X0.1Y0.1Z-0.25R0.1Q0.0625F15.0
    G80
    M6T3 R0
    M30
    Operation 2 is where the OP's question would come into play... so you'd want to put the tool change info (and tool header code) into this Upon Every... and probably just a comment in the ToolChange sequence...
    - joel
    ps: the "mod 1000" trick also mentioned works great (i use 1000 not 100 in the hopes of someday having a machine with over 100 tools but its main flaw: you have to change tool numbers when you move operations around, insert toolpaths, etc... it becomes cumbersome... but i still use it for a "production" posted program that maybe have one specific operation (like finishing pass after a long cycle of roughing with the same tool... those cases where the "DComp" post above is too slow (ie too many z-retractions at the toolchange... which i guess could be eliminated in the macros but mine home z at every toolchange right now)
    pps: and what i actually use this DComp trick for is the lathes, switching between CSS and RPM, and IPM and IPR:
    Code:
    Upon Every [DComp]
    '( OPERATION ' h[block] ' )'
    if [SpeedType] = [val4] AND [Speed] = [val5]
    else
    Call Custom1   # Speed(Type) Change
    endif
    if [FeedType] <> [val6]
    Call Custom3   # FeedType Change
    endif
    End
    Feb 2006
    49
    if your on maintenance contact surfware and ask them how? but they will limit the amount of time they will give this.
    There is a option in spost to get the type of operation (OPERTN/6,-1,-1) but i dont think its available in mpost. I asked them to put it in mpost about 4 years ago but there not that quick. if the oper function is in mpost you could varialble the tool information and use a "if then" function inside the toolchange area.
    the operation feature is key to what you want to do, it will help you to automaticly put in the type of path information into your g-code.
    May 2012
    100
    Does toollist exist also for turning tools? In that case,
    anyone that have a list of turning tools, or know how to
    figure it out?
    May 2003
    70
    Great reading all the tips and tricks you guys have found to make it work for you, I am going to use some of these in my shop tomorrow.
    What a lot of people don't know is that Mpost isn't a Surfware product, it's the "lite" version of posthaste from Posthaste post processor (Home_
    Paul Andrews makes and sells the full version and provides awesome support for a very low cost.
    If you need to take Mpost to the next level, this is your only option.
    Oct 2009
    13
    Wish there were some way to pass the tool library reference number to the mpost to avoid having 2 drills with the same tool number. We switch between tool numbers 19 and 25 (drill chucks), but that's not foolproof. On a big piece we may use 50 or more drills. I've seen some good ideas here, though.
    thanks,
    nick.
    May 2013
    Quote Originally Posted by sinderal View Post
    Hi Torro:
    I can't download your post, industryarena, popped up blank.
  1. Surfcam Post Processor
    By drakesis in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-14-2013, 04:22 AM
  2. Surfcam post?
    By Lasershop in forum Centroid CNC Control Products
    Last Post: 02-09-2009, 08:35 PM
  3. Do surfcam has post for Mach3?
    By jinu117 in forum Surfcam
    Last Post: 12-28-2007, 11:51 AM
  4. Surfcam post for g71
    By villiersterrace in forum Haas Mills
    Last Post: 08-03-2006, 12:44 AM
