587,316 active members*
3,320 visitors online*
Results 1 to 13 of 13
    Jun 2009
    31
    whip on lead screw
    I am looking for some help i am trying to get rid of the whip on my z lead screw it is 1800 mm long and 12mm in diameter any ideas how i can lose the bad whip i am thinking of using m16 or m18 screw
    Mar 2009
    163
    i would go with 25mm with 10mm lead minumum, it will still whip but at a higher rpm
    look up on ebay LinearMotionBearings they have decnetly priced screws.
    Aug 2008
    573
    That's a serious Z axis
    12mm seems a little light for a screw of that length it has a core of only about 10mm.
    One option (other than increasing the diameter of the screw) is to re-engineer the axis so the screw is stationary and taut between mounts, while the nut rotates (i.e. the nut is mounted, with the drive motor, on the gantry)
    Bill
    Jun 2009
    35
    How fast do you want to spin, and what is the pitch of the screw?
    The 25mm diameter screw with 10mm lead recommended above is rated for 362 inches per minute. Is that enough?
    1" diameter with a 1/2" lead gets you up to 468 i.p.m.
    Matt Adams - Motion Control Application Engineer
    IMAC Motion Control - Elgin, IL
    Jun 2009
    31
    i got confused it should be the x axis lol funny considering i am a cnc machinist for a living
    Jun 2009
    31
    thanks for all the help guys i have re designed it so the nut rotates rather than the screw
    Aug 2008
    573
    Quote Originally Posted by badassdevil View Post
    Pictures - or it didn't happen....!
    Bill
    Mar 2004
    1661
    Very good idea, I use rotating nuts myself and they are very well performing. I can "pre-tension" the screw and even though my screws are as long as yours (but thicker though, 16 and 20 mm) I have no problem driving my axis at 15-20 meters per minute, that's about 600-800 IPM.
    Pictures not needed, I have videos.
    [ame="http://www.youtube.com/watch?v=NkFSWTjDHjA"]YouTube - 20090416012[/ame]
    [ame="http://www.youtube.com/watch?v=Ejed_tbt4Ho"]YouTube - 20090416010[/ame]
    Nov 2005
    160
    Looks like this thread is sorted- FWIW though, all the big screw manufacturers provide equations for predicting whip in their data sheets. A quick run through of those would prevent nasty surprises, and could probably be *roughly* used with other no name brand screws as well, for hobby use.
    Jun 2009
    31
    screw whip
    the system in your vids is very simular to mine and it works just great length is no longer and issue so in my opinion a better system
    Aug 2008
    573
    Come on then, where are the pictures ?????
    Bill
    Jun 2008
    16
    Are there any commercial/stock rotating nut ball screws? The examples I've found here look custom or at least partially fabricated. I'd rather spend the money on that part instead of the time.
    Quote Originally Posted by jurban View Post
    Well, there's two styles, belt driven and motor-integrated. Both require very nice rotary bearing sets. Thk, hiwin, nb, I think all make a belt driven nut. they are all ground ballscrews and all quite expensive.
    Bosch Rexroth makes motor integrated types in sizes larger than NEMA34. My company makes NEMA23 size in both 16mm and 20mm ballscrew diameters, with leads from 5mm to 40mm. That last one will do 2.5m/sec. Mine are not exactly budget minded either, having very nice spindle bearing sets and zero backlash ballscrews.
  1. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  2. lead screw whip ? bearing to use and why?
    By technomage in forum Linear and Rotary Motion
    Last Post: 05-08-2007, 12:16 AM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. Lead screw whip
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 08:04 PM
