587,753 active members*
2,906 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > micro-mark mini mill cnc conversion suggestions
Page 1 of 2 12
Results 1 to 20 of 27
    Jun 2009
    33
    Hi everyone, new to this forum. I'm an wood and metal working hobbyist. Build furniture, boxes, hand planes etc. Been at at it for several years. Started metal with the taig lathe a few years ago and now have the micro-mark lathe and mini-mill.
    Thinking of converting the X2 to CNC and been reading a lot about it on the net. Not sure if i should buy the stuff from chinese e-bay guy for 270 US or from one of the american companies. Then there is the instructions for the conversion, where to get them, and the software to go with it. Don't have any projects in mind other than the conversion.
    Seems most people spend more time tinkering and tooling there machines than actually building anything. Cant say I'm not guilty of that as well.
    Any suggestions welcome, thanks again
    Do you have a link for the chinese Ebay guy?
    There are DIY conversions and kit conversions like Cncfusion.
    Keling carries motors, drivers and power supplies etc.
    Mach 3 is the best for controlling the mill for PC users.
    I have some links for some of the CAD CAM and other useful software.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2009
    33
    A FEW QUESTIONS
    Ok, so ordered the cnc kit #4 with upgrades and the G540 with four 387's. Got the wire locally and now have a few other questions.
    1. What is required for speed control on the X2 spindle and how do I wire it up?
    2. Are the resistors required 3.48K 1/4 watt? and how many do I need and where do I wire them too?
    3. Does the spindle control offer both foward and reverse for tapping? The x2 I have (micromark) does not have a reverse speed on the control.
    4. Has anyone used a 4" rotary table from micromark as the 4th axis and what coupler does it require
    5. Why is this such an expensive hobby???
    Feb 2007
    4553
    Post
    Waldermac,
    You will need a 3.48K resistor for each stepper motor.
    Solder the resistor to pins 1 and 5 of the DB9 connector.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jun 2009
    33
    Thanks jalessi
    Any info on the other questions??
    Feb 2007
    4553
    Post
    Waldermac,
    Is this is the rotary table you are referring to?
    http://www.micromark.com/MILLING-MAC...ABLE,8218.html
    Make a mount like the one in the attached jpg
    Hoss machine has a very kewl tapping attachment for the X2.
    http://www.hossmachine.info/projects_8.html
    Little Machine Shop has several motor controller's
    http://littlemachineshop.com/product...1211&category=
    http://littlemachineshop.com/product...3194&category=
    Jeff...
    Jun 2009
    33
    Yes thats the rotary table. Love the tapping attachment. Guess I will need a C10 board from cnc4pc to control another stepper motor.
    So to control spindle speed I need to buy a new controller board from LMS. I cant use the board that comes with the mill?
    I'm thinking a belt drive conversion is a must as well.
    I have the MT3 spindle. Is it worth it to convert to R8 or leave it. I already have the tooling for the MT3 but not a huge investment
    Feb 2007
    4553
    Post
    Waldermac,
    I am not familiar with the controller in your machine.
    There is a engineer that repairs the controllers, he will be able to answer your questions.
    http://www.www.repaircontrol.com/
    [email protected]
    Ask for John Gerling
    I don't own "MT@#$ anything"
    Falling out and breaking a tool sucks!
    You don't really need a C10 use the A axis on your G540
    99 percent of the time you wont be using the rotary while tapping.
    How hard is it to unplug the DB9 connector?
    Or if you use the same size stepper for the rotary and the tapping function a 4PDT switch will handle the task for about five dollars.
    http://tinyurl.com/nlpa7g
    Just don't flip the switch with the G540 power on.
    Jeff...
    Jun 2009
    33
    My controller is not broken, I just want to control spindle speed with Mach3. If I want to built an ATC and use tormach stuff would the R8 or MT3 make any difference?
    Feb 2007
    4553
    Post
    I know your controller is not broken, you want reverse or variable speed right?
    Ask John Gerling if that is possible.
    MT... whatever will be a big problem with a tool changer.
    Do you have your air conditioning on today?
    Jeff...
    Feb 2007
    4553
    Tormach tool holders will not fit MT3.
    Jun 2009
    33
    Of course air conditioning is on! Its 30 degrees celcius here in Toronto. I emailed John so waiting to hear back. I ordered 3 limit switches, was I supposed to get 6? I thought one for each axis except the 4th.
    Jun 2009
    33
    his reply
    Shawn,
    I wish I could help but my expertise is limited to SIEG straight motor controllers.
    My guess is that IF the spindle is not have a rotation position reference to anything else and uses the original motor, then the original controller will work
    Wish I could be of more help.
    John Gerling
    shawn wrote:
    Hi there. Was referred to you by cnczone. I am converting an X2 to cnc using the g540. My question is : what is required to control the spindle with mach3. Do I need another controller or can I use the one on the machine, and if so are any other parts required and how do I hook it up to the G540. Not sure if you can help me but no harm in asking.
    Thanks so much
    Shawn.
    Feb 2007
    4553
    Post
    Three switches will be fine, setup soft limits for the apposing ends of each axis.
    May 2005
    1662
    Quote Originally Posted by jalessi View Post
    LMS claim both MT3 and R8 will work. They also have a MT3 version of their tool changer. Here's the collet
    http://littlemachineshop.com/product...gory=209730719
    Don't ask me how well it works, I swapped the MT3 spindle on my X2 to R8 before buying a few of the Tormach goodies. Buying a bunch or MT3 tooling felt like a poor investment.
    MT3 is usable but takes a bit of a touch when tightening.
    To loose is dangerous.
    To tight and you'll be using a 3LB hammer to pop the taper.
    Jun 2009
    33
    Ok good. I though I was doing something wrong when I had to hammer out each tool. My threads on my draw bar are almost bare from the hammering. I wonder if I can change my drill chuck, collet holder and facemill to R8 by just changing the MT3 posts to R8 posts. Possible? Machinable? I have the 7 x 14 lathe as well.
    Jun 2009
    33
    Oh, and adjustable boring head as well.
    May 2005
    1662
    Quote Originally Posted by Waldermac View Post
    The drill chuck and facemill should be possible unless the drive lugs are integral with the taper for some reason. I'm not sure about the collet holder. If you switch to Tormach style holders it's a different ballgame anyway. Seeing as you have a lathe, take a look at Hoss's tool holders for some money saving ideas. LMS doesn't explicitly list a facemill stub among their quick change tooling although they do list a boring head adapter.
    Switching from a MT3 (3MT) to a R8 Tormach system is simply a matter of changing the 3/4" collet. The rest is reusable if you decide to change spindle tapers.
    edit/ Rethinking this, small facemills are unlikely to use drive lugs. Most likely completely integral with the taper.
    Jun 2009
    33
    wiring
    Ok, got the motors and power supply and g540. Can anyone show me how to wire the power supply to the G540. The power supply doesn't come with a plug and I'm a little confused as to what goes where and don't want to blow myself up here. Some sort of detailed drawing would be great. Its the KL-600-48.
    I downloaded the schematic
    Attached Files Attached Files
    Feb 2008
    521
    Its all on the Gecko spec sheet .... 48v+ to screw terminal 11 (from memory) and Ground to screw terminal 12
    I assume you've got the 110/220v AC side covered?
    http://www.geckodrive.com/upload/G54...3%20MANUAL.pdf
Page 1 of 2 12
  1. Micro-Mark Microlux 7x14 Mini Lathe
    By Jaime128 in forum Mini Lathe
    Last Post: 06-02-2010, 04:22 AM
  2. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
  3. CNC for mini-lathe by SIEG (Micro-mark, HF, etc)
    By JohnELMDAS in forum Mini Lathe
    Last Post: 01-24-2008, 02:07 AM
  4. suggestions for micro mill
    By Hawkeye21 in forum Benchtop Machines
    Last Post: 01-12-2008, 01:45 AM
  5. Micro Mark Mini mill converstion
    By cncadmin in forum Vertical Mill, Lathe Project Log
    Last Post: 02-08-2005, 04:27 AM
