587,262 active members*
3,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > micro-mark mini mill cnc conversion suggestions
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Jun 2009
    33
    maybe
    Is this right?
  2. #22
    Feb 2007
    4553
    Post
    Power supply connection.
    Attached Files Attached Files
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #23
    Jun 2009
    33
    A/C
    Thanks,
    For the A/C side, do I have that right?
    Green is ground - bolt to chasis or power supply
    Black to HoT
    White to Neutral?
    And the E-Stop has 4 terminals
    One of the green pin 10
    One of the red to -V
    Thanks, don't want to be guessing here
  4. #24
    Feb 2007
    4553
    Post
    Green/Ground connects to the FG terminal.
    Black connects to pin1 AC/L (line)
    White connects to pin2 AC/N (neutral)
    E-STOP SWITCH: Connect a single pole, single throw (SPST) switch to the DISABLE input Pos 10 on the MAIN TERMINAL BLOCK. The other end of the switch goes to Pos 12 on the terminal block. Opening the switch disables the G540 and closing the switch enables it. While disabled, the motors freewheel (zero torque) and the OUTPUT
    terminals shut off.
  5. #25
    Jun 2009
    33
    Thanks again
    Ok I think I got it now.
    On the Gecko G540 manual, in the suggested wiring diagram, it specifies a Relay power supply with two dc relay coils. Do I need that? What is that for? They connect to pins 5 and 6.
    Will pins 7,8, and 9 if connected to my X2 motor control actually control my spindle speed with mach 3? I think I asked this already but didn't get any clear answers.
  6. #26
    Feb 2007
    4553
    Post
    The relay's are optional, they could be used to control a coolant pump or a simple enable/disable spindle motor etc...
    You may be able to use the VFD output for your X2, the Gecko VFD connection would take the place of the potentiometer on the X2.
    I am not sure which one of the wires on the pot is the output though.
    The attached video is informative.
    [ame="http://www.youtube.com/watch?v=ELj9G14ayOM"]YouTube - 67: Sieg X2 Mini Mill Electronics[/ame]
    Jeff...
  7. #27
    Jun 2009
    33
    Well I got all the motors turning fine in mach3. I used the G540 presets. Has the steps at 20000 and they seem to turn pretty slow. Anyone know the ideal settings for the 387 motors with the cnc fusion ballscrew upgades. I'm referring here to steps, velocity, acceleration under the motor tuning page.
Page 2 of 2 12
  1. Micro-Mark Microlux 7x14 Mini Lathe
    By Jaime128 in forum Mini Lathe
    Last Post: 06-02-2010, 04:22 AM
  2. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
  3. CNC for mini-lathe by SIEG (Micro-mark, HF, etc)
    By JohnELMDAS in forum Mini Lathe
    Last Post: 01-24-2008, 02:07 AM
  4. suggestions for micro mill
    By Hawkeye21 in forum Benchtop Machines
    Last Post: 01-12-2008, 01:45 AM
  5. Micro Mark Mini mill converstion
    By cncadmin in forum Vertical Mill, Lathe Project Log
    Last Post: 02-08-2005, 04:27 AM
